Individually Sleeved Power Cables
StrongestBite
31
I am looking to purchase individually sleeved power cables for the PC that I am building in two days. I will hook these up to my modular power supply.
I am looking for white cables and I see on Amazon that you can purchase them individually. The only problem is, I have no idea how many I need of each cable. Is there some way to figure this out?
These are the cables I am looking at: LINK
And this is the PC I am building:
MOBO: GIGABYTE GA-X79-UD3 LGA 2011
CPU: Intel i7-4930K
CPU Cooler: Corsair H100i Liquid Cooling
GPU: 2x EVGA GeForce GTX 780Ti 3GB in SLI
RAM: Corsair Dominator Platinum 16GB (2x8GB) DDR3 1600 MHz
SSD: Samsung 840 Pro 256GB
PSU: Corsair RM Series 1000 Watt ATX/EPS 80PLUS
Sound: Asus XONAR ESSENCE
Case: Corsair Obsidian Series 750D
Case Cooling: Corsair AF120 High Performance Fans
These DO NOT plug into your PSU. They are EXTENSIONS for existing cables.
You need:
1- 24pin (motherboard)
1- 8 (4x4) pin (CPU)
4- 8pin PCI cables (GPUs)
I would also recommend changing the PSU. That unit is made with low quality capacitors that like to fail.
Go Antec, XFX, Seasonic, Corsair (not CX, CS, RM).
Everything from video editing to gaming to poker. I will be doing everything at a high resolution 2560x1440 (and possibly 3x this if I get two more monitors) so I figured the 780ti SLI config would be great for ultra settings on games at this resolution.
Okay Tiny Voices, thank you for the input. I will take a look at a 4770k + z87 combination. I was simply trying to make this PC as overkill as possible so I won't even consider upgrading it for a few years.
+1 I have a 4770K and at stock it basically (couple minutes longer) encodes movies for my NAS in real time OC is even faster.
