EDIT: Solved --- The card was defective (most likely the fan controller malfunctioned) i sent it back to the retailer and i'm waiting for a replacement card.
Hi
So, I have a problem, i got an inno3D GTX 1080
First off my setup is as follows:
GIGABYTE MB GB 1150 Z97X-SLI
Int Core i5-4690K
WESTERN DIGITAL HD3.5" SATA3 2TB WD20EURX / AV-GP (Di)
XFX 550W 80+ BRONZE CERTIFIED WIRE
PHANTEKS PH-TC14CS Cooler
2x KINGSTON 8GB DDR3- 1866MHZ NON-ECC CL 1
Another 2 SATA with 1TB each and an SSD with 256GB (I don't have the exact types of those)
inno3D GTX 1080 Chill x4
i installed it and tried running it with my current setup and encountered a problem, the fans are not working at all. The tiny fan on the side activated once on the first startup after i installed the card but since then all 4 fans are standing still. The card has an LED on the side indicating load (from the descriptions i've found online my guess would be that it actually indicates power load and not temperature) and it is blue all the time meaning the card is not under load. I tried to play a bit of overwatch and noticed FPS drops after about 15 minutes, a quick glance to the statistics told me that the card was running at almost 90°C so i immediatley turned off the PC and let the card cool down. After some testing i found out that none of the fans come online and the card doesn't change from blue load to the two others (under gaming it should be red).
Furthermore, manually setting the fan speed in the inno3D tool or MSi afterburner also didn't start the fans.
What I noticed as well is that when the fan speed is set to automatic it actually changes based on the cards temperature as if the fans were running.
Do you guys think that the fans not working is due to the PSU maybe not giving the card enough power? Or do you have any other suggestion? (already ordered a Corsair CP-9020092-EU RMX 750W just to be on the safe side)
Driver wise i'm running the current nvidia 390.65 drivers and did a clean install of them (deleted my old cards drivers properly etc.).
Any input would be appreciated. I'll update this as soon as i changed the PSU as well.
Here are two pictures of the LED and fans
And one of the CPUID HWMonitor
It looks like the fans should be getting power but aren't moving :< bad card?
Hi
Int Core i5-4690K
