Hey, I'm having a really hard time with my high end computer I can't find any solution for almost half a year. So, I had a PC that I build in September 2021 (RTX 3080, Ryzen 7 5800X, 32gb of ram, X570 chipset, 2x m.2 ssd, 360mm aio, 850W power supply, 2x high refresh rate monitors) everything was fine from the beginning, no input lag, no delay, no mouse/keyboard problem, until one day in March this year, I woke up from a night shift, turned on the PC and noticed that my mouse and keyboard feels weird when moving around in desktop / games and when typing (bad mouse responsiveness in games when moving my mouse, like it's really slow, floaty, not accurate, delay when moving in games or when typing), I tried everything, reinstalling windows multiple times, changing every hardware (components, peripherals), changing ISP, moving to another house and nothing helped.
So I sold my PC thinking that there was some sort of a problem that I just couldn't figure out. Then I build a second PC with all new parts that are listed below, except PSU and monitors, hoping everything will be fixed, but it didn't fix anything at all. It's still there and I'm out of ideas
.. I'm playing csgo competitively on high level, so I have some muscle memory but now when I'm trying to click on something with this input lag/delay it's like I've never used my mouse before.. and when this problem occures I can't play ANY games because it's so unresponsive. It also feels like I'm playing on low refresh rate and low fps when this input lag/delay kicks in.
The input lag, floatyness and other stuff is even more noticeable when installing windows 10. Also, I have a 850W power supply, and when I did that power supply calculator thingy from outervision website, the recommended PSU wattage for my new PC build is 585W which is odd because on the Gigabyte GPU website the recommended PSU is 750W.. and then I tried another calculator from newegg, the recommended PSU wattage there was 800-899 W. So I'm thinking that even when my PSU has 850W it is somehow not efficient enough to power my components(?). I have two monitors, 240hz and 144hz and none of them had any issues before, but this input lag is happening on both monitors.
I didn't try to replace my monitor with another because I have no option to do so right now. And also I want to upgrade to 1000W PSU and see if it makes any difference.
New pc:
CPU - Ryzen 9 5900X
GPU - Gigabyte RTX 3080 VISION
RAM - 2x16GB of RAM @3600MHz
MB - Gigabyte B550 VISION D-P
Cooler - Asus ROG STRIX LC II 280 AIO
PSU - Gigabyte AORUS P850W 80+ GOLD (not replaced)
Storage - 500GB of M.2
Main monitor - Asus TUF VG259QM @ 240hz (DisplayPort) (not replaced)
Second monitor - ZOWIE by BenQ XL2411P @ 144hz (DisplayPort) (not replaced)
3x 120mm case fan
2x 140mm case fan
New pc:
CPU - Ryzen 9 5900X
3x 120mm case fan
2x 140mm case fan
