Hello, I just assembled my new build. AMD FX 6300 CPU, Corsair value-select 4x2 GB RAM, Asus M5A97 mobo, Zotac GTX 660 GPU...
When I connect my GPU to my DELL monitor, it says " the current input timing is not supported by the monitor display. please change your input timing to 1600x900 @ 60hz or any other monitor listed timing as per monitor specifications."
This message shows without even booting into BIOS. This means I can't interact with the system at all. Would really appreciate all help and suggestions.
I put in my old GPU (nvidia 520gt) that has VGA and it works!! I can get into the bios. My temperatures are cool. But dvi doesn't work on the old or new GPU.. The new one doesn't have VGA. I even tried a dvi to VGA adapter... Still not working. My monitor doesn't have HDMI.
While using DVI onmy old or new GPU, I only get the message mentioned above. I can't get into the BIOS or Advanced Boot Menu.
Please help me out. I'd really appreciate all suggestions. Thanks
