Insane FPS drop all of a sudden. Please help.
Amozzo
27
4 days back I upgraded my PC with new RAM, CPU, CPU Cooler, GPU and an SSD. I moved OS and some games to my SSD and it worked fine for 2 days. Next thing I know is that my fps is split in 3 and on the lowest settings I am getting fewer fps than on my old build. I have installed drivers and BIOS, cleaned my PC from junk, checked for virus and malware etc etc... If someone has experienced the same or knows a fix, please post an answer. Thanks in advance.
Sorry, and a new MOBO. (MSi H110M Gaming if that helps.)
If you have a full new system and using an operating system that was installed on an old system, that could very well be your problem. I would do a fresh install of Windows on your new system and see if you have the same issues (I doubt you will).
I'll get back to you after the fresh install. Wish me luck... Haha
GPU temp - ~54 deg celcius
CPU temp - ~46 deg celcius
Mobo - MSi H110M Gaming
GPU - Palit GTX 1060 6GB Super Jetstream
CPU - Intel Core i5 6600 (Non K)
PSU - Corsair CX600 600W
RAM - Corsair Vengeance LPX 8GB 2666MHz (1x8)
CPU Cooler - Intel Stock
HDD - Seagate Barracuda 1TB
SSD - Crucial MX300 275GB
64bit Windows 10 Home Premium
