Hi,
I recently installed a new Motherboard. I had a BM85-G before and now I have Asrock H81 Pro BTC R2.0.
I made a fresh install of windows on my SSD by deleting the partitions and installing windows on the SSD.
If I restart the computer it starts up just fine, but if I shut it down it keeps the lights on the power button and it doesnt turn off. If i then hold down the power button and turn it off that way it cannot boot windows.
If I choose the boot order option and choose my SSD it doesn't boot, it seems like there is nothing to boot with a blinking _
If I put my USB with the windows UEFI installer into the PC and boot from that, as if I want to install windows again, and then choose "repair" and then choose "continue to windows" then it works perfectly fine.
When the PC is on I can see that the files are installed correctly on my SSD - it is not installed on the USB.
Does anyone have an idea what this could be? False wiring or something completely different? I really hope there is a solution to this
Thanks in advance!
Thanks in advance!
