[SOLVED] Installing 3600mhz kits in a motherboard that supports 3200mhz only
Samuel-212
Commendable
Jan 25, 2023
38
Hello,
Today I received my 16x2gb ram kits and I noticed that they have sent me 16x2gb @ 3600mhz despite the fact that I had order 16x2gb 3200mhz. My motherboard is an Asus h610m a and it only supports 3200mhz so what should I do right now ?
CPU: i5 12400f
Mobo: Asus h610m a
Install the RAM and look if it has XMP for 3200 Mhz. It might have.
If not, look if you can manually OC the RAM from BIOS with correct frequency.
Overall, RAM will work at JEDEC speeds of 2133/2400/2666 Mhz.
Latest posts
