Installing AOC Monitor Drivers! (Need help)
FireClocks
82
How do I install the drivers on my new AOC G2460PF 144hz Gaming monitor?
It comes with a CD but my pc actually doesn't have a CD reader.
So I went to the website and download "the drivers" but it's a folder with stuff inside, and none of it runs when I double click.. Am I supposed to put the folder somewhere? I don't get it ;_;
When I turn the Monitor on it says "No signal"
FireClocks
82
[quotemsg=20422223,0,2210382]Right click on the INF file and select install.
[/quotemsg]
It was that easy haha, thanks!
Btw, to get the 144hz option I use the DP cable only or is it more than one at the same time?
Thanks
[quotemsg=20422333,0,2421536][quotemsg=20422223,0,2210382]Right click on the INF file and select install.
[/quotemsg]
Thanks
[/quotemsg]
You will probably have fewer issues with a DP cable. But a HDMI 2.0 link should work too on newer free-sync monitors (not 100% sure that your AOC supports this).
