Installing Samsung 950 Pro M.2 not working
Boestro
33
Dear,
I've bought a Samsung 950 Pro 250GB and put it in my motherboard (MSI Z97 Gaming 9 ACK with M.2 slot) with windows 10 installed. Then i've downloaded the Samsung nvm driver version 1.0 but it says: Samsung NVM Express device is not connected, please connect your device. Anyone knows what I have to do now?
Thanks for the help
i'd go thru your mobo manual and review it's recommended bios settings - i've already forgotten but iirc you've installed the SSD in your M.2 socket - and most of the Z97 mobos' M.2 socket is limited to PCIe 2.0 x2
here's a snap of my magician, 950 is installed in a M.2 > PCIe adapter expansion card in a PCIe 3.0 x4 slot
for the hell of it, download and install samsung's data migration software and see if it will allow you to clone the OS drive to the 950 - their data migration software has done some interesting things - if it will, let it - if you don't want the 950 as your OS drive, then simply wipe the drive but at least you'll have it recognized
and btw, in the m.2 socket on your z97 mobo, very few z97 boards have 4 lanes (or x4) on their M.2 socket. If you don't see read speeds much over 800 MB/s, you know why
I've downloaded the newest version for my motherboard from the MSI website and installed it with flash in the bios setup and it's installed but it still says outdated, I tried samsung nvm driver again but it says: please connect samsung ssd. Also I found this in my motherboard manual: 1Intel RST does not support PCIe M.2 SSD with Legacy ROM 2 M.2PCIe interface does not support RAID 0, Raid 1, RAID5 and RAID 10.
Maybe there is another way to update my bios?
"Intel RST does not support PCIe M.2 SSD with Legacy ROM"
verouderd = Legacy, therefore SSD not working.
You have to go in BIOS, Set ▶Boot Mode to UEFI and reinstall Windows. It would be a good opportunity to install it on the new SSD.
I can't help you more. You can google about differences between UEFI and Legacy.
I've installed the UEFI and it shows up in system information. But the samsung NVM driver installer still says that I have to connect a Samsung device. Is there a next step?
for whatever reason your driver is not seeing the M.2 device, the 950 - it may be the 950 isn't seated properly in the M.2 socket or the socket is bad.
I'd suggest getting a M.2 > PCIe expansion card adapter and installing the 950 on it in one of the PCIe 3.0 x4 slots - it that works, you know that socket or the circuit to it is bad
fwiw
I've checked the M.2 and it's plugged in good; also i don't have a PCie 3.0 x4 slot; also in my bios he doesn't see anything in the M.2 slot, is my motherboard bios to old, because I don't get it
from the specifications page, your board has three PCIe 3.0 slots
"PCI-E Gen Gen3 (16, 0, 0), (8, 8, 0), (8, 4, 4) "
http://us.msi.com/product/motherboard/Z97-GAMING-9-ACK#hero-specification
the only info i could find on your M.2 slot is "Push your SSD to the limit with M.2 & SATA Express" - you ought to check your owner's manual for that mobo to confirm it's a PCIe M.2 socket and not sata
either the 950 is defective, not seated properly in the socket, or the socket (or it's circuit) is bad
It is a M.2 port, I checked the manual, when I touch my Samsung SSD i feel it is warm, so that means it works i think, are there other programms then samsung nvm installer to check if the M.2 works or something?
being an M.2 port does not mean it's PCIe - it could be a sata M.2 - they do exist, which means the 950 would not show up in your system
that's why i suggested a) checking your manual to confirm it's a PCIe socket, not a sata connection
2nd suggestion, is to get an expansion card adapter and try the 950 in that - if the system recognizes it, then either the M.2 is a sata channel, or it's defective. The 950 being warm doesn't rule either of those two possiblities out - it simply tells you it's getting power
Yes a UEFI bios or Legacy + UEFI, I can send the ssd back to where I bought it and they pay me back then, so there is nothing I can do now without that PCIe expansion card, nothing drivers or something?
something just cropped up on the asus mobo support forum that hadn't occurred to me as my mobo doesn't support sata express - a user with a similiar mobo to yours, his bios keeps resetting to sata express from M.2
in your bios settings, have you selected M.2? - you'll have to check your mobo user's manual for the location of the settings choice - but that could well be the issue
Well i changed form UEFi boot to UEFi + lagacy mode and now i can boot my windows from there, so that means he is still working, but I will now try installing the drivers on it.
OMG guys, SSD is connected; NVM drivers are installed another big shit out of my live, can I transfer my windows 10 from my intel SSD to samsung SSD with Samsung date migration?
yes - but when you do, and reboot, you'll find the intel drive "offline" - you'll be able to see it in disk management
reason is, samsung's data migration software copies the OS drive exact, including labeling the partitions the exact same, ie "C", "D" etc, so the system can't have duplicate partitions. You might want to try the freeware version of Macrium Reflect - like other clone software, it will label the new drive's partitions as "J (C)", K (D)", so both drives will be available
the samsung migration software was fast though, under 10 minutes for 177 GB - you can always use a partition management software to wipe the intel drive after cloning, so you can use it for storage
But when I boot my pc up with the samsung SSD 950 Pro it says it'ss not a good booting device, but when I boot with the UEFI HArd DIsk: Windows Boot Manager, windows starts and OS is on the 950 pro, is this normal?
