Intel Confidential - Help
hsjnlssmith
I purchased a CPU off of E-Bay that was listed as a QX6700 socket 775 CPU. What I got was a CPU that has "Intel Confidential" stamped on it and the following info:
QQMM ES A4
HH80562PH0678M
L625A65W
How do I find out what type of CPU it is?
What you have is a ES (engineering sample) thats normally only given out to test sites. Normally it will be a bit better than retail and you might want to contact Intel.
The last guy who got one was trying to get the same CPU you were trying to get but got a ES one and when he contacted Intel ended up getting a QX6850 if I remember correctly which was not even out for public yet. So contact Intel and see what they say.
That sounds like an engineering sample.If so,the multiplier is probably unlocked and you'll be able to overclock the heck out of it.INTEL may give you a decent CPU in return for it,but think of the clock rates you should be able to get out of it.Goodluck.
Dahak
ASUS P5N-D
C2D E8500 STOCK
ZALMAN 9500 CPU COOLER
2X2GIG DDR2 1066 IN DC MODE
TOUGHPOWER 850WATT PSU
EVGA GTX 260
SMILIDON RAIDMAX GAMING CASE
LG 24IN WS LCD 1920X1080
250GIG HD/500GIG HD
LOGITECH G15 GAMING KEYBOARD
G5 GAMING MOUSE
LOGITECH Z-5500 5.1 SURROUND SYSTEM
500WATS CONTINUOUS,1000 PEAK
WIN XP PRO
I have a similar issue, I just bought a tower off a guy that was hurting for cash and I got it for a good deal I think $500, It is listed as a Intel Core 2 Extreme QX6800 Kentsfield @ 2.93Ghz Socket 775 with CPUZ and under Specification it is listed as Q6800 ES, When I looked on the CPU it say's Intel Confidential QXWX ES ...And there is some other numbers on the processor, It is hard to make out. I myself was told that this was a good CPU and that it is very exspensive to buy. I am not sure if it is a good CPU and whether to sell it and grab something else or to just keep it. As for the rest of the PC I will list below what it came with, and if anyone could let me know if you think I paid a fair price or to much for it. The specs below are what I bought it with a week ago. And the fellow I got it off told me he bought this all brand new about 8 months ago and he paid a lot for it.
-Intel Core 2 Extreme QX6800 @ 2.93GHz LGA775
-Intel Extreme D975XBX2 Motherboard
-4GB Patriot Extreme Performance DDR2 PC2-6400 Low Latency PDC22G6400LLK 4 x 1GB
-Zalman CNPS9700 LED 3 Speed CPU Cooler With Fan Mate Fan Control
-Antec 900 Gaming Case 4 Fans LED
-MSI GeForce NX8800 GTX HD-OC 768MB
-Thermaltake TR2 550W Power Supply
-1 x Western Digital Raptor 160GB WD1600ADFS 10,000Rpm SATA
-2 x Western Digital 160GB WD1600AVBS 7200Rpm SATA
-LiteOn 20X DVD-RW With Light Scribe SATA
-2 Black Light Cathode Lights
