News Intel expects behemoth 144-core Sierra Forest chips to boost per-rack performance by 2.7X at lower power
Headline: Intel expects behemoth 144-core Sierra Forest chips to boost per-rack performance by 2.7X at lower power
Wrong.
Try reading your own source, maybe??
"Intel Xeon next-gen processors, code-named Sierra Forest, launching later this year will offer up to 288 cores and help operators recognize a 2.7x performance per rack[1] improvement – an industry leading performance per rack for 5G Core workloads[2]."
Notes:
  1. Based on estimated architectural projections as of Feb. 14, 2024, vs. prior-generation platforms as of 2021. Your results may vary.
  2. Based on Intel analysis and publicly available data as of Feb. 20, 2024.
Source: https://www.intel.com/content/www/u...c-2024-next-gen-xeon-improvement-5g-core.html
This clearly suggests they're talking about the 288-core version delivering the 2.7 speedup! "Prior-generation as of 2021" means they're probably referring to Ice Lake.
That puts 106 cores at just below one 40-core (80-thread) Ice Lake, which is very plausible, since each E-core is said to have similar IPC to a single-threaded Skylake, while Ice Lake delivered real IPC gains relative to Skylake and could run at slightly higher frequencies than Sierra Forest. Not to mention hyper-threading.
In contrast, the notion that their 144-core CPU is 2.7x as fast as an 80-thread Ice Lake-SP, just isn't credible.
@JarredWaltonGPU can you check me on this?
Wrong.
"Intel Xeon next-gen processors, code-named Sierra Forest, launching later this year will offer up to 288 cores and help operators recognize a 2.7x performance per rack[1] improvement – an industry leading performance per rack for 5G Core workloads[2]."​
Notes:
Thanks for the feedback, as always! The source doesn't say they used a 288-core, as noted in the text, and they didn't. Here is the response from Intel on the test setup:
"Here’s the claim: (2.7x improvement) This claim is comparing SRF 2S 144C vs widely deployed Telco config of 6252N 2S. So 144-core."
I added some text in the article to represent the additional info. We'll see if INtel will also clear up the workload info, too.
Reactions: bit_user
It's marketing but also true, the key word here is low(er) power, and we know that at very low power the e-cores will be a lot more efficient than the p-cores.
Especially since they are not saying "as fast" as you are saying, they say performance per rack at low power.
At least that's what I think.
Thanks for checking with Intel. This is very helpful, due to the way they worded that sentence.
Okay, so we should consider the match-up of 144-core Sierra Forrest vs. 24-core Cascade Lake. That would be six times as many cores and three times as many threads. So, a 2.7x speedup indeed seems plausible (since IPC is roughly similar and scaling is usually sub-linear).
Thanks! Two observations about that...
First, this part:
"... will offer up to 2.7X higher performance per rack ..."
Seems like it should be "... will offer up to 2.7X as much performance per rack ...".
Second, the sentence:
"Intel says that its choice of comparing two 24-core processors against two 24-core models is to highlight a widely deployed telco config."
Did you perhaps mean to say "... two 24-core processors against two 144-core models ..." ?
While I'm nit-picking:
"a 2.7 times performance increase over a three-year-old platform is an impressive improvement"
Cascade Lake began launching in Q2 of 2019. It's essentially the same microarchitecture as the Skylake-SP series, that launched on virtually the same process node, back in Q3 2017. So, I guess the real question is whether Sierra Forest is about 5 or 7 years newer than what they're comparing it to?
: D
