Hi all, I am trying to max out my little i7 and would like some help/tip how to do so fast and securely.
I got it to run 4.2 Ghz for about 2 months without it crashing stock voltage, but it crashed yesterday, so I am wondering how to OC and be secure that it won't crash and how to not make it take a month to reach max. I find ring ratio and the adaptive/offset/manual voltage very confusing.
I use Windows 10 Pro with Realbench and OCCT for tests.
Ambient temp: 22 °C
Max temps running 4.0 Ghz:
Cpu: 43 °C
Cpu cores 52-57 °C
Gpu: 66 °C
Motherboard: 32 °C
All drives around 20-30 °C
This pc have mounted 2x 120 Front, 2x 120mm the radiator Liquid cooler Rear, 1x 120mm Top and buttom, plus a 200mm at the side.
Specs:
Thank in advance
D4YN3X
Btw if there is anything you don't understand or are insecure about just ask and I try explain it again.
Ambient temp: 22 °C
Cpu: 43 °C
Cpu cores 52-57 °C
Gpu: 66 °C
Motherboard: 32 °C
Specs:
Cooler Master 690 III with sidefan(without window)
Intel Core i7-4770K
ASUS MAXIMUS VI HERO
G.Skill F3-17000CL11-4GBXL
GIGABYTE GeForce GTX 970 G1 Gaming
Samsung SSD 850 PRO 256GB
4 x 1 TB WD 3.5"
Thank in advance
D4YN3X
