I was here a bit ago about a dead fan in a Cooler Master V8, even though the CPU temps were fine. I ended up replacing the fan and all was well.
However, I recently moved, and now when I turn the machine on (after being in a box and moved), and it shuts down after 1-2 minutes. Sometimes I get a heat warning from the BIOS if I try to turn it on right away, and when I entered the BIOS, it said that the CPU was running at 85 degrees celsius (chipset temps were 27, by contrast)
I did some looking at the cooler, and it looks a little uneven, but it's hard to be sure. I'm not sure how to tighten it, perhaps someone else knows better about this cooler?
Or would it make some sense to just order a new cooler?
