Hello, it's been awhile since I've posted anything on here, But I've hit a wall and I'm not sure how to solve the issue. So let me start, The problem is that when I turn multi-core enhancement on in bios, and then I try to run either prime 95 or handbrake, the pc then bsod's within 10 seconds of either running prime 95 or or starting to render video using handbrake.
I've tested the cpu, checked Motherboard pins and memory modules and all are fine and dandy. I was thinking it was a motherboard issue, so I swapped out the motherboard hoping that would solve the issue. but to my dismay there was no change. the first Motherboard was a asrock x299 Killer sli/ac and the second was a gigabyte x299x arours master. In addtion I checked voltages and power draw using occt I got a reading from the cpu of 280 to 430 watts. all the power supply voltages were normal according to occt. In addition, running multi-core enhancement on, in general leaves the computer running fine except prime 95 and handbrake. I did notice it blue screened once while playing cod modern warfare, with the multi-core enhancement turned on. but if I turn it off everything runs fine on the asrock motherboard. I did send back the gigabyte board back due to it not wanting to post after a software restart. and I have bought another motherboard and I'm just waiting on it to come it. but any idea's on what is causing the multi-core to crash the computer. Moreover, I've got a buddy running that gigabyte board and a 9900x, he as well gets the bsod with multi-core enabled, when running those two programs .
pc spec's
monitors
3 24 in asus 1920 x 1080
1 40 in lg 4k tv
balistic sport 2400 mhz ddr 4 memory
cpu 7960x
gpu gigabyte aorus 2080ti WBE
m.2 860 evo
1 optical drive
1 card reader
1 hotswap
aver media capture card c985
1 mechanical hhd
cooling specs
I've tried both cooling methods
Method one
cpu cooling
480mm X 60mm raid
phobia waterblock
8 Noctua NF-F12 iPPC 3000 PWM push/pull configuration
alphacool d5 pump none pwm
2 Noctua NF-F12 iPPC 3000 PWM front Intake and 1 for exhaust
for gpu loop
2 Noctua NF-A14 iPPC-3000 PWM
280mm x 60 mm raid.
Method 2
cpu cooling
noctua d15 air cooler
psu 1300 watt super nova gold rating
gpu loop carries over and so does the 2 front intake fans and 1 exhaust fan in the rear , However, I've taken the 8 fans in the top and removed 4 and turned then into 4 additional intake fans.
and speed setting is on silent except for cpu fans which are maxed.
In addition, I've looked at event viewer on my system and my buddies and when both systems suffer from the dreaded crash, event viewer log's it as power kernal 41.
consequently, if the turbo boost 3.0 is enabled without multi-core enhancement turned on I get the same crash . but if I turn on McE and turn off all turbo boosts, it works normal and no crashes. I do feel as if it's a power issue. Furthermore, if turbo boost 3.0 along with McE is enabled and the standard turbo boost is disabled, the pc doesn't crash in prime 95 , but the video signal to my 4 monitors goes out, indicating a massive power draw.Lastly, the cpu is not being overclocked and I'm trying to get it to run with in intel's specifications.
pc spec's
monitors
1 40 in lg 4k tv
cpu 7960x
m.2 860 evo
1 optical drive
1 card reader
1 hotswap
1 mechanical hhd
cooling specs
Method one
cpu cooling
480mm X 60mm raid
phobia waterblock
for gpu loop
280mm x 60 mm raid.
Method 2
cpu cooling
