T800-101
Benches on Intel graphics hardware? Surely you jest.how so? please post your benches
Lol, so it's still the fastest, duh.That isn't a disadvantage. Because 64-bit with Core 2 Duo doesn't slow down compared to 32-bit, it gains performance!!! The performance impact of the "lack of support" is less than 5% in most of cases. People seem to be almost paranoid of the lack of some performance features for 64-bit. But it doesn't matter!! Cause it still kicks any other CPU even in 64-bit. 25% performance advantage is now 20%!! Who cares!!
With initial versions of 64-bit with Pentium 4's, they actually had disadvantages of 64-bit, because it wasn't fully compatible with the x86-64. But Core 2 Duo does, just that you may lose few % of performance out of the tens of %.
dont claim it with out proof
i bet you could take intel integrated GFX and bench it compaired to amd and nvidia integrated GFX and get similar numbers. i only suggest this because if they all use UMA then they all have the same issues.but anyways make sure you compair apples to apples intel gfx costs the user 10-20 dollars
Well, beginning with Exchange 2007, all new MS server aps REQUIRE a 64bit CPU/OS. Office will probably be next. The Ribbon interface should greatly simplify upgrades to Office apps. All Office apps can benefit from large RAM sizes. Access, Excel, Word (media inserts), PowerPoint(even more media inserts).
If Itanium had caught on I'd bet all of you would be singing a different tune.
2. Switching from 8bit to 16bit and from 16bit to 32bit gave immediate advantages. Running a 64 bit OS with less than 4GB RAM gives no advantages whatsoever.
Of course sooner or later, machines with 4GB+ RAM will be common.
The point is that right now, probably 99%+ of all PCs have less than that and would gain NOTHING by going 64bit.
