Intel Rapid Storage Technology and Raid Setup for P9X79 Pro
leaflet757
20
I just flashed the BIOS for my P9X79 Pro motherboard and now I want to set up RAID so I can use Intel Rapid Storage Technology. Once the BIOS was updated, I switched the SATA configuration into RAID mode and then tried to set up a RAID volume. The problem is when I try to set up a RAID using the Intel Rapid Storage Technology tool, it does not give me any options to select disks for the RAID. Both disks are formatted and set as NON-RAID DISKS but it is still not letting me select them. I tried both RSTe and IRST settings in the BIOS and still no luck. Does anyone have any suggestions on how to get this working?
With that SSD I suggest installing Windows on it and using the HDD for data. Better results than Smart Response.
ISRT is recommended for small sizes SSDs.
1) Install Samsung Magician.
*Not only does it have firmware updates, benchmark etc but it lets you assign different PROFILES such as "maximum capacity" easily which does things like disable HIBERNATION to eliminate the Hiberfil which can take up several Gigabytes (i.e. 75% to 100% the amount of DDR3 memory you have).
2) Install STEAM, other games, and put media, downloads etc on the HDD. For example, I have Steam installed to :
"E:\Steam" and have
"E:\Downloads" (and folders for "Media", Backups)
3) BACKUP IMAGE:
You should use the free version of Seagate DiscWizard and make a compressed backup image of your SSD. Make an initial copy after everything's installed and working great, then make a SECOND copy later which you periodically replace. Keep that first one in case problems creep into later backups as reinstalling everything is a hassle.
4) about RAID:
In case it's not clear, what you were doing was not RAID at all which is why you had problems. Normally you'd have IDENTICAL discs set as RAID0 for better speed (data striped across both) or RAID1 for redundancy (same data on both drives).
What you were attempting to do as I guess you understand now is use the SSD and HDD together as a "Hybrid drive". Most of the hybrid drives you buy have only 8GB of SSD but use that for the files like bootup files that benefit most from the speed.
As said, it makes no sense to use a large SSD in this fashion since you can already fit the entire Operating System, programs etc on the SSD anyway.
Summary:
a) Samsung Magician
b) HDD for Steam games etc
c) Seagate DiscWizard backup Images
d) about RAID
