Operating System: Windows 10 Professional 64-Bit
Motherboard: Asrock G31M-S
Processor: Intel Xeon X5470
Graphics: R9 Fury 4G
Memory: Samsung DDR2 PC2-5300 8GB
Storage: Kingston A400 120 GB SSD (OS)
Storage: Western Digital Blue 500 GB (Games)
Power: Rosewill Glacier 700W 80+ Bronze
So basically, at all times, with the multiplier locked to 10, and the bus locked to 353, my core speed should be set to 3539.10 MHz. (BIOS Settings)
However, it often just hangs around 3.33 GHz in task manager. So I tested with Real Temp and CPU-Z and they both report the higher speed. But, all is not well, when I benchmark it, it reports the lower speeds, meaning realtemp and CPU-Z are reporting what it's supposed to be, while task manager and the benchmarks are showing the real speed.
I have tried:
I have tried:
- Reinstalling Windows
- Park Control
- Real Temp (disabling C1E)
- Power management (Have tried all profiles)
- reseating the CPU and checking for pin damage
- Modified the BIOS to force support by the motherboard for the processor
- Reset the CMOS
- Removed the multiplier and tried reapplying and different settings. (The real speed is always lower than the bus speed.)
