Based on the price, it is horrible. Even excluding Intel cpus, it's slower in non gaming workloads by way cheaper AMD products.
But, if someone primarily or exclusively cares about gaming, then the value-for-money isn't at all bad.
How am I moving the goalposts man?
You were carrying on about how chiplet CPUs are intrinsically inefficient and referencing this unproven anecdote about how your brother's Ryzen spikes up to 60 W, when browsing youtube comments. Showing a chiplet-based CPU doesn't necessarily behave that way is an easy bar for me to clear, so that's what I did. Now, you're trying to change the point of dispute to the question of whether
any power or efficiency gap exists between chiplet and monolithic. I never said it didn't and I certainly didn't ever say that a chiplet-based CPU was the most efficient. You moved the goalposts.
Just to be clear, I'm not calling you or your brother liars. I'm just saying that unless the data is independently generated and properly investigated to see if there's some bug or configuration problem behind it, I have to treat it as merely an anecdote. It also presumes the workload is effectively single-threaded, which I highly doubt.
Do you realize that every single 12th or 13th gen CPU can hit the 13400 efficiency numbers more or less just by restricting the clockspeeds?
No, that's a tall claim and must be proven. Especially the part about Gen 12 or any CPUs based on the Alder Lake H0 stepping die. I also question the relevance. It seems like you're trying to change the topic
yet again, in spite of
@thestryker 's statement of exasperation at this exchange.
I suspect the other thing going on is that you're trying a backdoor to the same issue of mismatched product comparisons, where you're going to say that because someone
can limit an i9-13900K to make it replicate the i5-13400F's efficiency, that it's valid to use its efficiency data for the i9-13900K. In which case, I would say that you
also have to use performance data collected when the i9 is configured like that.
Performance, performance, and efficiency are different sides of the same coin. They cannot be treated separately. This is why I like plots like the one I made from that ComputerBase.de article, since it shows efficiency as the actual
relationship between power and performance of the respective CPUs.
I'd argue a 13700k can do better simply because it can hit those clockspeeds with lower power. That is not the case with AMD cpus. You can't get a 7950x and make it match the R7's efficiency simply because it has twice the dies, no matter how low you drop the clocks it will still be pretty mediocre in 1T efficiency.
Heh, there you go with sweeping statements built on narrow facts. When I thought you were talking about efficiency, writ large, I was going to point out that you don't know the precise perf/W curve of Zen 4, without which you really can't say there's no point where it won't come out ahead. But, then comes the twist, where what
sounds like a broad claim actually turns out to be this weird fixation you have with 1T efficiency.
