Intel's Core i7-12700H processor Geekbenched, fails to impress with single-thread performance.
Intel's Core i7-12700H Benchmarked Against Apple's M1 Max : Read more
The scheduled forum maintenance has now been completed. If you spot any issues, please report them here in this thread. Thank you!
The chip architecture is hot and uses too high frequencies, in a notebook the performance will drop a lotThese results are really odd... And this is giving the benchers the benefit of the doubt and assuming all CPUs were 35W models. Alder Lake P cores (Golden Cove?) should be really good in single threading at the same clock speeds as RocketFailLake, so those results don't make sense to me. I think the CPU is being held back or maybe it's not inside a properly cooled laptop or they used an ES.
Regardless, if Laptop Alder Lake improves over Rocket Lake Laptop, it would be kind of lame.
Regards.
There are architectural improvements in IPC, so at the same clocks, it should show better performance, which is not in this case. Unless they're clocked lower than the competing Intel counterpart, which is the "sus" part.The chip architecture is hot and uses too high frequencies, in a notebook the performance will drop a lot
