O olchev57 Reputable Jul 13, 2015 4 0 4,510 Jul 13, 2015 #1 Looking for the bracket on a Williams demolition man that turns the interlock on and off. Its a bracket that goes on the door
COLGeek Cybernaut Moderator Apr 6, 2009 59,639 5,361 184,340 Jul 13, 2015 #2 You might check here: http://www.pbresource.com/ Upvote 0 Downvote
O olchev57 Reputable Jul 13, 2015 4 0 4,510 Jul 14, 2015 #3 Contacted them they do not carry the bracket Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 59,639 5,361 184,340 Jul 14, 2015 #4 Was worth a shot. Do you have the original bracket? If so you might find a metal shop to fabricate a new one. Upvote 0 Downvote
O olchev57 Reputable Jul 13, 2015 4 0 4,510 Jul 14, 2015 #5 I don't have the bracket, Looking at getting the interlock working without duck tape ....lol Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 59,639 5,361 184,340 Jul 14, 2015 #6 Velcro from the inside? I really don't know unless you can find a old (similar) unit being parted out. Even a picture would help to possibly make one. Good luck! Upvote 0 Downvote
