intermittent lan disconnection issues
josiahh
4
I have this setup :
HIS iCooler H775FN1G Radeon HD 7750 1GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card
ASRock H77 Pro4/MVP LGA 1155 Intel H77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Pentium G860 Sandy Bridge 3.0GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics BX80623G860
Western Digital WD Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive - OEM
COOLER MASTER Elite 431 Plus RC-431P-KWN2 Black Steel Body (0.5mm SECC), ABS plastic ATX Mid Tower Computer Case
Kingston HyperX XMP 10th Anniversary Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX16C9X3K2/8X
Antec VP-450 450W ATX 12V v2.3 Power Supply
LITE-ON DVD Burner Model iHAS124-04
I use Ethernet cord for the connection.
Its worked great since I got it. Recently (< 1 month) Ive had issues gaming online. tried a fresh reinstall of the OS and got all the video card/motherboard/etc drivers. Realtek and fast lan drivers for Lan. Unable to connect at a steady rate to play a online game. Need help troubleshooting. Side note, I have linux mint installed(dual boot) to see if windows 7 was the problem and it also disconnects from the web at intervals. Took the pc to my friends house to see if it was my internet connection but it does the same thing here. Could my motherboard be the culprit? Used various new ethernet cords so its not the problem.
have you tried using the PC without the X-fast setting enabled on the BIOS? that motherboard has a feature called X-fast LAN and it could be the culprit. if it has been enabled try using it disabled and enable it if it was previously disabled.
