Internet connection drops for 2 seconds
neather
Commendable
Mar 2, 2016
43
Ok so i start having this problem about 2 weeks ago
whenever I'm in games Pubg , For honor, Rocket league and Overwatch
I lose connection for about a second or 2 every 3-5 minutes
My laptop is wired directly to the router
I asked my network provider he said my network is working fine
My laptop is Lenovo z50-70
what router are you using? certain router versions use a chipset that have a similar problem.
i would make sure you don't have something like onedrive backing/sycning up your files every 5 minutes.
This is the router I'm using
TP link TL-WR941HP ( https://www.tp-link.com/au/products/details/cat-9_TL-WR941HP.html )
actually the problem I was thinking of was with the cable modem using the intel puma 6 chipset.
you can google your modem name + the word chipset to find out what chip it is using.s
you should try to isolate the problem down.
I would try a simple ping script to see if you can see the lag outside of your game.
if you do, then you would boot into windows safe mode with networking and run the script again to see if you still see the lag in safe mode. if you see the problem in both cases the problem is outside your machine, if only in windows full boot then something on your machine is causing the lag. some service using the network at intervals.
generally you would do a sniffer trace and look at the out put. but most people would have problems doing that.
you might run a cmd.exe or powershell as an admin then run
your ping to some server test. when you see a lag, go to another cmd.exe window and run
netstat.exe /b
it will show the name of the .exe that are currently making network connections. or ones that have just closed connections. it might help identify what is causing the lag if it is coming from your own machine.
here is microsoft's network sniffer:
https://www.microsoft.com/en-us/download/details.aspx?id=44226
(there is a large learning curve if you have never used a sniffer)
bugs in network drivers could cause errors that trigger timeouts
virus scanners can cause delays when data is downloaded.
firewalls can reject connections
you can run out of connections and a program might have to wait for a free connection.
I tried using that program but it was a bit complicated for me
but i did try doing the ping thing and i saw nothing wrong every connection says " established"
except one connection says " time wait "
and i connected my laptop straight to the internet without the router and i didn't lose connection
which is kinda weird cuz i got the router like a month ago so idk what's the problem
Update/
actually nvm even when straight connected without the router still the same problem
This what i got when i tried using this ping command thing
C:\WINDOWS\system32>netstat.exe /b
Active Connections
Proto Local Address Foreign Address State
TCP 127.0.0.1:1120 bandicam:6258 TIME_WAIT
TCP 127.0.0.1:1120 bandicam:6259 TIME_WAIT
TCP 127.0.0.1:1120 bandicam:6260 TIME_WAIT
TCP 127.0.0.1:1120 bandicam:6261 TIME_WAIT
TCP 127.0.0.1:1120 bandicam:6262 TIME_WAIT
TCP 127.0.0.1:1120 bandicam:6263 TIME_WAIT
TCP 127.0.0.1:1120 bandicam:6264 TIME_WAIT
TCP 127.0.0.1:1120 bandicam:6265 TIME_WAIT
TCP 127.0.0.1:1120 bandicam:6266 TIME_WAIT
TCP 127.0.0.1:1120 bandicam:6267 TIME_WAIT
TCP 127.0.0.1:1120 bandicam:6268 TIME_WAIT
TCP 127.0.0.1:2063 bandicam:2064 ESTABLISHED
[Battle.net.exe]
TCP 127.0.0.1:2064 bandicam:2063 ESTABLISHED
[Battle.net.exe]
TCP 127.0.0.1:6121 bandicam:49165 ESTABLISHED
[Overwatch.exe]
TCP 127.0.0.1:6146 bandicam:6463 ESTABLISHED
[Discord.exe]
TCP 127.0.0.1:6178 bandicam:10501 ESTABLISHED
[Overwatch.exe]
TCP 127.0.0.1:6179 bandicam:10502 ESTABLISHED
[Overwatch.exe]
TCP 127.0.0.1:6269 bandicam:1120 TIME_WAIT
TCP 127.0.0.1:6463 bandicam:6146 ESTABLISHED
[Discord.exe]
TCP 127.0.0.1:10501 bandicam:6178 ESTABLISHED
[Overwatch.exe]
TCP 127.0.0.1:10502 bandicam:6179 ESTABLISHED
[Overwatch.exe]
TCP 127.0.0.1:49165 bandicam:6121 ESTABLISHED
[Overwatch.exe]
TCP 192.168.8.178:5912 52.230.84.217:https ESTABLISHED
WpnService
[svchost.exe]
TCP 192.168.8.178:5916 37.244.54.10:1119 ESTABLISHED
[Battle.net.exe]
TCP 192.168.8.178:5931 104.16.59.37:https ESTABLISHED
[Discord.exe]
TCP 192.168.8.178:5939 unassigned:https ESTABLISHED
[Discord.exe]
TCP 192.168.8.178:5943 ec2-34-225-128-209:https ESTABLISHED
[RazerCentralService.exe]
TCP 192.168.8.178:5949 47:https ESTABLISHED
[Discord.exe]
TCP 192.168.8.178:5975 37.244.28.18:https ESTABLISHED
[Battle.net.exe]
TCP 192.168.8.178:6010 13.107.21.200:https ESTABLISHED
[SearchUI.exe]
TCP 192.168.8.178:6015 13.107.140.254:https ESTABLISHED
[SearchUI.exe]
TCP 192.168.8.178:6017 13.107.255.76:https ESTABLISHED
[SearchUI.exe]
TCP 192.168.8.178:6019 13.107.246.254:https ESTABLISHED
[SearchUI.exe]
TCP 192.168.8.178:6126 104.16.58.5:https ESTABLISHED
[Discord.exe]
TCP 192.168.8.178:6129 24.105.29.76:https ESTABLISHED
[Overwatch.exe]
TCP 192.168.8.178:6130 104.16.58.5:https ESTABLISHED
[Discord.exe]
TCP 192.168.8.178:6140 37.244.54.10:1119 ESTABLISHED
[Overwatch.exe]
TCP 192.168.8.178:6145 37.244.21.170:3724 ESTABLISHED
[Overwatch.exe]
TCP 192.168.8.178:6148 104.16.13.231:https ESTABLISHED
[Discord.exe]
TCP 192.168.8.178:6149 104.16.13.231:https ESTABLISHED
[Discord.exe]
TCP 192.168.8.178:6150 104.16.13.231:https ESTABLISHED
[Discord.exe]
TCP 192.168.8.178:6216 24.105.29.76:https ESTABLISHED
[Battle.net.exe]
TCP 192.168.8.178:6251 24.105.29.76:https ESTABLISHED
___________________
And here i pinged discord server to test it when i lost connection for a sec
C:\WINDOWS\system32>ping -t discordapp.com
Pinging discordapp.com [104.16.59.5] with 32 bytes of data:
Reply from 104.16.59.5: bytes=32 time=38ms TTL=54
Reply from 104.16.59.5: bytes=32 time=35ms TTL=54
Reply from 104.16.59.5: bytes=32 time=46ms TTL=54
Reply from 104.16.59.5: bytes=32 time=48ms TTL=54
Reply from 104.16.59.5: bytes=32 time=56ms TTL=54
Reply from 104.16.59.5: bytes=32 time=49ms TTL=54
Reply from 104.16.59.5: bytes=32 time=42ms TTL=54
Reply from 104.16.59.5: bytes=32 time=51ms TTL=54
Reply from 104.16.59.5: bytes=32 time=64ms TTL=54
Reply from 104.16.59.5: bytes=32 time=72ms TTL=54
Reply from 104.16.59.5: bytes=32 time=60ms TTL=54
Reply from 104.16.59.5: bytes=32 time=39ms TTL=54
Request timed out.
Reply from 104.16.59.5: bytes=32 time=34ms TTL=54
Reply from 104.16.59.5: bytes=32 time=33ms TTL=54
Reply from 104.16.59.5: bytes=32 time=45ms TTL=54
Reply from 104.16.59.5: bytes=32 time=36ms TTL=54
Reply from 104.16.59.5: bytes=32 time=47ms TTL=54
Reply from 104.16.59.5: bytes=32 time=70ms TTL=54
Reply from 104.16.59.5: bytes=32 time=41ms TTL=54
Reply from 104.16.59.5: bytes=32 time=32ms TTL=54
Reply from 104.16.59.5: bytes=32 time=77ms TTL=54
Reply from 104.16.59.5: bytes=32 time=52ms TTL=54
Reply from 104.16.59.5: bytes=32 time=90ms TTL=54
Reply from 104.16.59.5: bytes=32 time=87ms TTL=54
Reply from 104.16.59.5: bytes=32 time=37ms TTL=54
Reply from 104.16.59.5: bytes=32 time=44ms TTL=54
Reply from 104.16.59.5: bytes=32 time=119ms TTL=54
Reply from 104.16.59.5: bytes=32 time=93ms TTL=54
Reply from 104.16.59.5: bytes=32 time=43ms TTL=54
Reply from 104.16.59.5: bytes=32 time=29ms TTL=54
Reply from 104.16.59.5: bytes=32 time=96ms TTL=54
Reply from 104.16.59.5: bytes=32 time=62ms TTL=54
Reply from 104.16.59.5: bytes=32 time=389ms TTL=54
Reply from 104.16.59.5: bytes=32 time=487ms TTL=54
Reply from 104.16.59.5: bytes=32 time=520ms TTL=54
Reply from 104.16.59.5: bytes=32 time=67ms TTL=54
Request timed out.
Reply from 104.16.59.5: bytes=32 time=57ms TTL=54
Reply from 104.16.59.5: bytes=32 time=555ms TTL=54
Reply from 104.16.59.5: bytes=32 time=421ms TTL=54
Reply from 104.16.59.5: bytes=32 time=55ms TTL=54
Reply from 104.16.59.5: bytes=32 time=118ms TTL=54
Reply from 104.16.59.5: bytes=32 time=213ms TTL=54
Reply from 104.16.59.5: bytes=32 time=71ms TTL=54
Reply from 104.16.59.5: bytes=32 time=79ms TTL=54
Reply from 104.16.59.5: bytes=32 time=131ms TTL=54
Reply from 104.16.59.5: bytes=32 time=82ms TTL=54
Reply from 104.16.59.5: bytes=32 time=106ms TTL=54
Reply from 104.16.59.5: bytes=32 time=99ms TTL=54
Reply from 104.16.59.5: bytes=32 time=66ms TTL=54
i would stop RazerCentralService.exe and see if you still get a delay.
see if you can get the problem in safe mode, then you know its not a side effect of any of the software you have installed.
or disable your recording software. it was using a bunch of loopback connections.
Just tired it I couldn't open any game on safe mode
and yeah bandicam seems to have been open by itself i deleted it but still the same problem with the connection
I will probably wait and see what my internet provider have to say today when he comes for a check up
just run the ping test in safe mode and see if you see a delay or dropped packets
Here's what i got
C:\Users\alnaseem>ping discord.com
Pinging discord.com [104.17.154.99] with 32 bytes of data:
Reply from 104.17.154.99: bytes=32 time=63ms TTL=53
Reply from 104.17.154.99: bytes=32 time=45ms TTL=53
Reply from 104.17.154.99: bytes=32 time=65ms TTL=53
Reply from 104.17.154.99: bytes=32 time=57ms TTL=53
Ping statistics for 104.17.154.99:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 45ms, Maximum = 65ms, Average = 57ms
__________
C:\Users\alnaseem>netstat.exe /b
Active Connections
TCP 192.168.0.167:1655 a-0001:https ESTABLISHED
[SearchUI.exe]
TCP 192.168.0.167:1657 13.107.42.254:https ESTABLISHED
[SearchUI.exe]
TCP 192.168.0.167:1658 13.107.21.200:https ESTABLISHED
[SearchUI.exe]
TCP 192.168.0.167:1659 13.107.255.76:https ESTABLISHED
[SearchUI.exe]
TCP 192.168.0.167:1666 server-52-85-22-164:https ESTABLISHED
[SearchUI.exe]
TCP 192.168.0.167:1668 204.79.197.222:https ESTABLISHED
[SearchUI.exe]
TCP 192.168.0.167:1735 fra16s20-in-f14:https ESTABLISHED
[chrome.exe]
TCP 192.168.0.167:1746 155.133.229.250:27021 ESTABLISHED
[Steam.exe]
TCP 192.168.0.167:1887 151.101.112.133:https ESTABLISHED
[chrome.exe]
TCP 192.168.0.167:1916 155.133.233.66:http ESTABLISHED
[Steam.exe]
TCP 192.168.0.167:1917 109.224.42.32:http ESTABLISHED
[Steam.exe]
TCP 192.168.0.167:1918 109.224.42.32:http ESTABLISHED
[Steam.exe]
TCP 192.168.0.167:1922 152.195.133.58:http ESTABLISHED
[Steam.exe]
TCP 192.168.0.167:1925 109.224.42.48:http ESTABLISHED
[Steam.exe]
TCP 192.168.0.167:1926 109.224.42.48:http ESTABLISHED
[Steam.exe]
TCP 192.168.0.167:1929 152.195.133.58:http ESTABLISHED
[Steam.exe]
TCP 192.168.0.167:1936 ip-68-71-251-224:http TIME_WAIT
in safe mode try to ping in a loop to see if you set a packet drop. something like
ping.exe google.com n 1000
(will will run 1000 times)
or
ping.exe google.com -t
which will run until stopped.
look to see if there is a pattern of timeouts.
under a safe mode boot that matches the pattern under normal boot.
Ok so here's the one in the safe mode
___________________________
C:\Users\alnaseem>ping.exe google.com -n 1000
Pinging google.com [172.217.22.110] with 32 bytes of data:
Reply from 172.217.22.110: bytes=32 time=143ms TTL=46
Reply from 172.217.22.110: bytes=32 time=124ms TTL=46
Reply from 172.217.22.110: bytes=32 time=121ms TTL=46
Reply from 172.217.22.110: bytes=32 time=126ms TTL=46
Reply from 172.217.22.110: bytes=32 time=132ms TTL=46
Reply from 172.217.22.110: bytes=32 time=140ms TTL=46
Reply from 172.217.22.110: bytes=32 time=108ms TTL=46
Request timed out.
Reply from 172.217.22.110: bytes=32 time=221ms TTL=46
Reply from 172.217.22.110: bytes=32 time=911ms TTL=46
Reply from 172.217.22.110: bytes=32 time=769ms TTL=46
Reply from 172.217.22.110: bytes=32 time=284ms TTL=46
Reply from 172.217.22.110: bytes=32 time=145ms TTL=46
Reply from 172.217.22.110: bytes=32 time=438ms TTL=46
Reply from 172.217.22.110: bytes=32 time=233ms TTL=46
Reply from 172.217.22.110: bytes=32 time=168ms TTL=46
Reply from 172.217.22.110: bytes=32 time=571ms TTL=46
Reply from 172.217.22.110: bytes=32 time=583ms TTL=46
Reply from 172.217.22.110: bytes=32 time=326ms TTL=46
Reply from 172.217.22.110: bytes=32 time=706ms TTL=46
Reply from 172.217.22.110: bytes=32 time=893ms TTL=46
Reply from 172.217.22.110: bytes=32 time=403ms TTL=46
Reply from 172.217.22.110: bytes=32 time=413ms TTL=46
Reply from 172.217.22.110: bytes=32 time=292ms TTL=46
Reply from 172.217.22.110: bytes=32 time=450ms TTL=46
Reply from 172.217.22.110: bytes=32 time=339ms TTL=46
Reply from 172.217.22.110: bytes=32 time=318ms TTL=46
Reply from 172.217.22.110: bytes=32 time=195ms TTL=46
Reply from 172.217.22.110: bytes=32 time=187ms TTL=46
Reply from 172.217.22.110: bytes=32 time=115ms TTL=46
Reply from 172.217.22.110: bytes=32 time=202ms TTL=46
Reply from 172.217.22.110: bytes=32 time=265ms TTL=46
Reply from 172.217.22.110: bytes=32 time=169ms TTL=46
Reply from 172.217.22.110: bytes=32 time=214ms TTL=46
Reply from 172.217.22.110: bytes=32 time=193ms TTL=46
Reply from 172.217.22.110: bytes=32 time=267ms TTL=46
Reply from 172.217.22.110: bytes=32 time=164ms TTL=46
Reply from 172.217.22.110: bytes=32 time=161ms TTL=46
Reply from 172.217.22.110: bytes=32 time=110ms TTL=46
Reply from 172.217.22.110: bytes=32 time=188ms TTL=46
Reply from 172.217.22.110: bytes=32 time=111ms TTL=46
Reply from 172.217.22.110: bytes=32 time=191ms TTL=46
Reply from 172.217.22.110: bytes=32 time=172ms TTL=46
Reply from 172.217.22.110: bytes=32 time=141ms TTL=46
Reply from 172.217.22.110: bytes=32 time=197ms TTL=46
Reply from 172.217.22.110: bytes=32 time=157ms TTL=46
Reply from 172.217.22.110: bytes=32 time=196ms TTL=46
Reply from 172.217.22.110: bytes=32 time=190ms TTL=46
Reply from 172.217.22.110: bytes=32 time=272ms TTL=46
Reply from 172.217.22.110: bytes=32 time=200ms TTL=46
Reply from 172.217.22.110: bytes=32 time=128ms TTL=46
Reply from 172.217.22.110: bytes=32 time=183ms TTL=46
Reply from 172.217.22.110: bytes=32 time=146ms TTL=46
Reply from 172.217.22.110: bytes=32 time=225ms TTL=46
Reply from 172.217.22.110: bytes=32 time=150ms TTL=46
Reply from 172.217.22.110: bytes=32 time=321ms TTL=46
Reply from 172.217.22.110: bytes=32 time=127ms TTL=46
Reply from 172.217.22.110: bytes=32 time=112ms TTL=46
Reply from 172.217.22.110: bytes=32 time=159ms TTL=46
Reply from 172.217.22.110: bytes=32 time=109ms TTL=46
Reply from 172.217.22.110: bytes=32 time=434ms TTL=46
Reply from 172.217.22.110: bytes=32 time=359ms TTL=46
Reply from 172.217.22.110: bytes=32 time=136ms TTL=46
Reply from 172.217.22.110: bytes=32 time=122ms TTL=46
Reply from 172.217.22.110: bytes=32 time=139ms TTL=46
Reply from 172.217.22.110: bytes=32 time=120ms TTL=46
Reply from 172.217.22.110: bytes=32 time=125ms TTL=46
Reply from 172.217.22.110: bytes=32 time=142ms TTL=46
Reply from 172.217.22.110: bytes=32 time=151ms TTL=46
Reply from 172.217.22.110: bytes=32 time=350ms TTL=46
Reply from 172.217.22.110: bytes=32 time=209ms TTL=46
Reply from 172.217.22.110: bytes=32 time=119ms TTL=46
Reply from 172.217.22.110: bytes=32 time=123ms TTL=46
Reply from 172.217.22.110: bytes=32 time=309ms TTL=46
Reply from 172.217.22.110: bytes=32 time=184ms TTL=46
Reply from 172.217.22.110: bytes=32 time=201ms TTL=46
Reply from 172.217.22.110: bytes=32 time=134ms TTL=46
Reply from 172.217.22.110: bytes=32 time=116ms TTL=46
Reply from 172.217.22.110: bytes=32 time=118ms TTL=46
Reply from 172.217.22.110: bytes=32 time=129ms TTL=46
Reply from 172.217.22.110: bytes=32 time=155ms TTL=46
Reply from 172.217.22.110: bytes=32 time=149ms TTL=46
Reply from 172.217.22.110: bytes=32 time=135ms TTL=46
Reply from 172.217.22.110: bytes=32 time=104ms TTL=46
Reply from 172.217.22.110: bytes=32 time=147ms TTL=46
Reply from 172.217.22.110: bytes=32 time=113ms TTL=46
Reply from 172.217.22.110: bytes=32 time=130ms TTL=46
Reply from 172.217.22.110: bytes=32 time=94ms TTL=46
Reply from 172.217.22.110: bytes=32 time=105ms TTL=46
Reply from 172.217.22.110: bytes=32 time=106ms TTL=46
Reply from 172.217.22.110: bytes=32 time=117ms TTL=46
Reply from 172.217.22.110: bytes=32 time=148ms TTL=46
Reply from 172.217.22.110: bytes=32 time=154ms TTL=46
Reply from 172.217.22.110: bytes=32 time=137ms TTL=46
Reply from 172.217.22.110: bytes=32 time=131ms TTL=46
Request timed out.
Reply from 172.217.22.110: bytes=32 time=102ms TTL=46
Reply from 172.217.22.110: bytes=32 time=133ms TTL=46
Reply from 172.217.22.110: bytes=32 time=765ms TTL=46
Request timed out.
Reply from 172.217.22.110: bytes=32 time=495ms TTL=46
Reply from 172.217.22.110: bytes=32 time=249ms TTL=46
Reply from 172.217.22.110: bytes=32 time=259ms TTL=46
Reply from 172.217.22.110: bytes=32 time=138ms TTL=46
Reply from 172.217.22.110: bytes=32 time=107ms TTL=46
Reply from 172.217.22.110: bytes=32 time=114ms TTL=46
Reply from 172.217.22.110: bytes=32 time=165ms TTL=46
Reply from 172.217.22.110: bytes=32 time=101ms TTL=46
Reply from 172.217.22.110: bytes=32 time=97ms TTL=46
Reply from 172.217.22.110: bytes=32 time=185ms TTL=46
Reply from 172.217.22.110: bytes=32 time=152ms TTL=46
Reply from 172.217.22.110: bytes=32 time=266ms TTL=46
Reply from 172.217.22.110: bytes=32 time=144ms TTL=46
Reply from 172.217.22.110: bytes=32 time=199ms TTL=46
Reply from 172.217.22.110: bytes=32 time=158ms TTL=46
Reply from 172.217.22.110: bytes=32 time=160ms TTL=46
Reply from 172.217.22.110: bytes=32 time=348ms TTL=46
Reply from 172.217.22.110: bytes=32 time=283ms TTL=46
Request timed out.
Reply from 172.217.22.110: bytes=32 time=250ms TTL=46
Reply from 172.217.22.110: bytes=32 time=175ms TTL=46
Reply from 172.217.22.110: bytes=32 time=223ms TTL=46
Reply from 172.217.22.110: bytes=32 time=205ms TTL=46
Reply from 172.217.22.110: bytes=32 time=351ms TTL=46
Reply from 172.217.22.110: bytes=32 time=251ms TTL=46
Reply from 172.217.22.110: bytes=32 time=156ms TTL=46
Request timed out.
Reply from 172.217.22.110: bytes=32 time=98ms TTL=46
Reply from 172.217.22.110: bytes=32 time=163ms TTL=46
Reply from 172.217.22.110: bytes=32 time=469ms TTL=46
Reply from 172.217.22.110: bytes=32 time=247ms TTL=46
Reply from 172.217.22.110: bytes=32 time=320ms TTL=46
Reply from 172.217.22.110: bytes=32 time=437ms TTL=46
Reply from 172.217.22.110: bytes=32 time=260ms TTL=46
Reply from 172.217.22.110: bytes=32 time=274ms TTL=46
Reply from 172.217.22.110: bytes=32 time=167ms TTL=46
Reply from 172.217.22.110: bytes=32 time=456ms TTL=46
Reply from 172.217.22.110: bytes=32 time=257ms TTL=46
Reply from 172.217.22.110: bytes=32 time=442ms TTL=46
Reply from 172.217.22.110: bytes=32 time=336ms TTL=46
Reply from 172.217.22.110: bytes=32 time=338ms TTL=46
Reply from 172.217.22.110: bytes=32 time=654ms TTL=46
Reply from 172.217.22.110: bytes=32 time=626ms TTL=46
Reply from 172.217.22.110: bytes=32 time=609ms TTL=46
Reply from 172.217.22.110: bytes=32 time=153ms TTL=46
Reply from 172.217.22.110: bytes=32 time=181ms TTL=46
Reply from 172.217.22.110: bytes=32 time=303ms TTL=46
Reply from 172.217.22.110: bytes=32 time=489ms TTL=46
Reply from 172.217.22.110: bytes=32 time=399ms TTL=46
Reply from 172.217.22.110: bytes=32 time=96ms TTL=46
Reply from 172.217.22.110: bytes=32 time=100ms TTL=46
Reply from 172.217.22.110: bytes=32 time=264ms TTL=46
Reply from 172.217.22.110: bytes=32 time=467ms TTL=46
Reply from 172.217.22.110: bytes=32 time=323ms TTL=46
Reply from 172.217.22.110: bytes=32 time=629ms TTL=46
Reply from 172.217.22.110: bytes=32 time=880ms TTL=46
Reply from 172.217.22.110: bytes=32 time=722ms TTL=46
Reply from 172.217.22.110: bytes=32 time=453ms TTL=46
Reply from 172.217.22.110: bytes=32 time=232ms TTL=46
Reply from 172.217.22.110: bytes=32 time=203ms TTL=46
Reply from 172.217.22.110: bytes=32 time=362ms TTL=46
Reply from 172.217.22.110: bytes=32 time=263ms TTL=46
Request timed out.
Reply from 172.217.22.110: bytes=32 time=253ms TTL=46
Reply from 172.217.22.110: bytes=32 time=290ms TTL=46
Reply from 172.217.22.110: bytes=32 time=312ms TTL=46
Reply from 172.217.22.110: bytes=32 time=278ms TTL=46
Reply from 172.217.22.110: bytes=32 time=262ms TTL=46
Reply from 172.217.22.110: bytes=32 time=313ms TTL=46
Reply from 172.217.22.110: bytes=32 time=432ms TTL=46
Reply from 172.217.22.110: bytes=32 time=380ms TTL=46
Reply from 172.217.22.110: bytes=32 time=224ms TTL=46
Reply from 172.217.22.110: bytes=32 time=238ms TTL=46
Reply from 172.217.22.110: bytes=32 time=231ms TTL=46
Reply from 172.217.22.110: bytes=32 time=365ms TTL=46
Reply from 172.217.22.110: bytes=32 time=212ms TTL=46
Reply from 172.217.22.110: bytes=32 time=194ms TTL=46
Reply from 172.217.22.110: bytes=32 time=412ms TTL=46
Reply from 172.217.22.110: bytes=32 time=210ms TTL=46
Reply from 172.217.22.110: bytes=32 time=166ms TTL=46
Reply from 172.217.22.110: bytes=32 time=337ms TTL=46
Reply from 172.217.22.110: bytes=32 time=217ms TTL=46
Reply from 172.217.22.110: bytes=32 time=287ms TTL=46
Request timed out.
Reply from 172.217.22.110: bytes=32 time=162ms TTL=46
Reply from 172.217.22.110: bytes=32 time=99ms TTL=46
Request timed out.
Reply from 172.217.22.110: bytes=32 time=95ms TTL=46
Reply from 172.217.22.110: bytes=32 time=186ms TTL=46
Reply from 172.217.22.110: bytes=32 time=170ms TTL=46
Reply from 172.217.22.110: bytes=32 time=173ms TTL=46
Reply from 172.217.22.110: bytes=32 time=171ms TTL=46
Request timed out.
Reply from 172.217.22.110: bytes=32 time=302ms TTL=46
Reply from 172.217.22.110: bytes=32 time=379ms TTL=46
Reply from 172.217.22.110: bytes=32 time=261ms TTL=46
Reply from 172.217.22.110: bytes=32 time=324ms TTL=46
Reply from 172.217.22.110: bytes=32 time=377ms TTL=46
Reply from 172.217.22.110: bytes=32 time=300ms TTL=46
Reply from 172.217.22.110: bytes=32 time=322ms TTL=46
Reply from 172.217.22.110: bytes=32 time=376ms TTL=46
Reply from 172.217.22.110: bytes=32 time=289ms TTL=46
Reply from 172.217.22.110: bytes=32 time=367ms TTL=46
Reply from 172.217.22.110: bytes=32 time=586ms TTL=46
Reply from 172.217.22.110: bytes=32 time=461ms TTL=46
Reply from 172.217.22.110: bytes=32 time=243ms TTL=46
Reply from 172.217.22.110: bytes=32 time=198ms TTL=46
Request timed out.
Reply from 172.217.22.110: bytes=32 time=176ms TTL=46
Reply from 172.217.22.110: bytes=32 time=177ms TTL=46
Reply from 172.217.22.110: bytes=32 time=180ms TTL=46
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.110: bytes=32 time=103ms TTL=46
Reply from 172.217.22.110: bytes=32 time=92ms TTL=46
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 172.217.22.110:
Packets: Sent = 1000, Received = 978, Lost = 22 (2% loss),
Minimum = 92ms, Maximum = 911ms, Average = 160ms
Here's the one without the safe mode
C:\WINDOWS\system32>ping.exe google.com -n 1000
Pinging google.com [172.217.22.78] with 32 bytes of data:
Reply from 172.217.22.78: bytes=32 time=290ms TTL=45
Reply from 172.217.22.78: bytes=32 time=200ms TTL=45
Reply from 172.217.22.78: bytes=32 time=264ms TTL=45
Reply from 172.217.22.78: bytes=32 time=253ms TTL=45
Reply from 172.217.22.78: bytes=32 time=266ms TTL=45
Reply from 172.217.22.78: bytes=32 time=302ms TTL=45
Reply from 172.217.22.78: bytes=32 time=233ms TTL=45
Reply from 172.217.22.78: bytes=32 time=157ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=162ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=175ms TTL=45
Reply from 172.217.22.78: bytes=32 time=141ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=188ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=156ms TTL=45
Reply from 172.217.22.78: bytes=32 time=227ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=835ms TTL=45
Reply from 172.217.22.78: bytes=32 time=894ms TTL=45
Reply from 172.217.22.78: bytes=32 time=460ms TTL=45
Reply from 172.217.22.78: bytes=32 time=515ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=161ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=596ms TTL=45
Reply from 172.217.22.78: bytes=32 time=372ms TTL=45
Reply from 172.217.22.78: bytes=32 time=561ms TTL=45
Reply from 172.217.22.78: bytes=32 time=575ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=230ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=196ms TTL=45
Reply from 172.217.22.78: bytes=32 time=241ms TTL=45
Reply from 172.217.22.78: bytes=32 time=225ms TTL=45
Reply from 172.217.22.78: bytes=32 time=219ms TTL=45
Reply from 172.217.22.78: bytes=32 time=194ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=171ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=191ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=187ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=174ms TTL=45
Reply from 172.217.22.78: bytes=32 time=199ms TTL=45
Reply from 172.217.22.78: bytes=32 time=244ms TTL=45
Reply from 172.217.22.78: bytes=32 time=155ms TTL=45
Reply from 172.217.22.78: bytes=32 time=186ms TTL=45
Reply from 172.217.22.78: bytes=32 time=195ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=428ms TTL=45
Reply from 172.217.22.78: bytes=32 time=549ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=189ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=319ms TTL=45
Reply from 172.217.22.78: bytes=32 time=147ms TTL=45
Reply from 172.217.22.78: bytes=32 time=259ms TTL=45
Reply from 172.217.22.78: bytes=32 time=181ms TTL=45
Reply from 172.217.22.78: bytes=32 time=148ms TTL=45
Reply from 172.217.22.78: bytes=32 time=160ms TTL=45
Reply from 172.217.22.78: bytes=32 time=217ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=142ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=222ms TTL=45
Reply from 172.217.22.78: bytes=32 time=213ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=192ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=293ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=164ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=205ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=211ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=177ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=231ms TTL=45
Reply from 172.217.22.78: bytes=32 time=158ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=172ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=165ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=167ms TTL=45
Reply from 172.217.22.78: bytes=32 time=176ms TTL=45
Reply from 172.217.22.78: bytes=32 time=228ms TTL=45
Reply from 172.217.22.78: bytes=32 time=184ms TTL=45
Reply from 172.217.22.78: bytes=32 time=216ms TTL=45
Reply from 172.217.22.78: bytes=32 time=239ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=229ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=224ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=180ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=183ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=170ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=163ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=168ms TTL=45
Reply from 172.217.22.78: bytes=32 time=149ms TTL=45
Reply from 172.217.22.78: bytes=32 time=166ms TTL=45
Reply from 172.217.22.78: bytes=32 time=152ms TTL=45
Reply from 172.217.22.78: bytes=32 time=132ms TTL=45
Reply from 172.217.22.78: bytes=32 time=145ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=151ms TTL=45
Reply from 172.217.22.78: bytes=32 time=204ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=137ms TTL=45
Reply from 172.217.22.78: bytes=32 time=126ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=150ms TTL=45
Reply from 172.217.22.78: bytes=32 time=127ms TTL=45
Reply from 172.217.22.78: bytes=32 time=153ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=139ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=159ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=202ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=203ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=154ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=286ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=218ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=134ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=143ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=128ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=133ms TTL=45
Reply from 172.217.22.78: bytes=32 time=140ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=252ms TTL=45
Reply from 172.217.22.78: bytes=32 time=327ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=123ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=130ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=135ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=125ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=138ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=120ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=129ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=210ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=122ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=136ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=221ms TTL=45
Reply from 172.217.22.78: bytes=32 time=178ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=212ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=169ms TTL=45
Reply from 172.217.22.78: bytes=32 time=117ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=131ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=121ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=119ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=124ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=214ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=118ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=144ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=112ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=185ms TTL=45
Reply from 172.217.22.78: bytes=32 time=179ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=242ms TTL=45
Reply from 172.217.22.78: bytes=32 time=238ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=146ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=114ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=116ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=107ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=257ms TTL=45
Reply from 172.217.22.78: bytes=32 time=190ms TTL=45
Reply from 172.217.22.78: bytes=32 time=201ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=220ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=109ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=173ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=207ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=269ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=250ms TTL=45
Reply from 172.217.22.78: bytes=32 time=382ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=209ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=275ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=258ms TTL=45
Reply from 172.217.22.78: bytes=32 time=536ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=542ms TTL=45
Reply from 172.217.22.78: bytes=32 time=301ms TTL=45
Reply from 172.217.22.78: bytes=32 time=340ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=368ms TTL=45
Reply from 172.217.22.78: bytes=32 time=390ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=439ms TTL=45
Reply from 172.217.22.78: bytes=32 time=470ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=341ms TTL=45
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=182ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=247ms TTL=45
Reply from 172.217.22.78: bytes=32 time=223ms TTL=45
Reply from 172.217.22.78: bytes=32 time=384ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=331ms TTL=45
Reply from 172.217.22.78: bytes=32 time=485ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=662ms TTL=45
Reply from 172.217.22.78: bytes=32 time=548ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=314ms TTL=45
Request timed out.
Reply from 172.217.22.78: bytes=32 time=276ms TTL=45
Reply from 172.217.22.78: bytes=32 time=466ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=206ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=245ms TTL=45
Reply from 172.217.22.78: bytes=32 time=365ms TTL=45
Reply from 172.217.22.78: bytes=32 time=317ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=197ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.22.78: bytes=32 time=193ms TTL=45
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 172.217.22.78:
Packets: Sent = 1000, Received = 665, Lost = 335 (33% loss),
Minimum = 107ms, Maximum = 894ms, Average = 176ms
well, there is some problem, it can be the network driver (same driver in both the safe mode and normal mode)
it can be the router, or the isp.
normally you should not get any dropped packets.
what is the name, date and time stamp for your network driver?
you can use autorun to see the name, and date of the network driver.
https://docs.microsoft.com/en-us/sysinternals/downloads/autoruns
this is the wireless one:
RTWlanE Realtek Wireless LAN 802.11n PCI-E Network Adapter: Realtek PCIE NDIS Driver 67668 32984 Realtek Semiconductor Corporation c:\windows\system32\drivers\rtwlane.sys 14/08/2018 08:43
I think this one counts too idk :
rt640x64 Realtek RT640 NT Driver: Realtek 8125/8136/8168/8169 NDIS 6.40 64-bit Driver Realtek c:\windows\system32\drivers\rt640x64.sys 15/08/2018 10:38
if you have any other computer device that is connected to the same router/internet
you could run a ping test to see if it gets the same dropped packets.
just to eliminate the computer as the cause.
you should also specify if the dropped packets were over the wireless or over the wired connection.
if it is a wireless connections you would need to see if your router is on the same channel as a nearby router. use wifi analyzer from Microsoft app store.
(I assume you used a wired connection, maybe try a different cable but not sure why there would be a pattern to the dropped packets with a bad cable)
if the wireless driver is a usb device, then make sure you update the bios and the motherboard drivers for the cpu chipset and any USB 3.x chipset driver. also, usb devices are effected by other USB devices plugged into the ports.
for example, if you charge a apple device and do not have a special charging port. the driver can detect overcurrent and shut down the hub several times a second.
both drivers look like the current ones from realtek
Done them all before posting this tbh ( except finding out the chipset used ) I first checked for updates using windows and DriverEasy pro
then i used Malwarebytes + windows built in anti virus to check for anything ( it found 3 threats but it didn't fix the problem )
I searched on google and found a post some guys changing his dns to google and got it fixed so i changed it and it still the same tbh
Guys i think i found the fix I changed the DHCP from default ( 120 in min ) to the maximum 2880 and now times out not happening after few secons ( it still happens but not as annoying as before )
gonna update it if i find a better fix
sadly i don't have any other pc/laptop but
I just tried to ping it on my phone (wireless network ) and on my laptop ( wired )
times out happens only on my laptop but the pinging on the phone doesn't show any "timed out" I'm gonna try gaming on wireless network and see if there's any change
Update : I just checked wireless and wired and still lose connection on my laptop
This problem really pisses me off
the game that had most effect is for honor i can't finish a match without getting kicked everytime
In Overwatch it happens but like every 2-4 matches which is fine
any network hack tools installed like windivert64.sys ?
or any tools that change the network priority? either thru bios or via a driver that changes network packets for games? I see these mostly with killer ethernet cards or with malware that is hack network packets to steal info from your machine.
