iphone 7 plus issues, wifi
Asleepdann
31
basically i had an issue with my phone where i could not even turn wifi on it was greyed out so i restarted my phone and it fixed that but then after i connect it says im connecte but whenever i try to go on fb or messenger it says im offline im super confused
hey jo i did that it seemed to work for a little bit but it eventually cuts off the wifi, now its permanently off i dont even have the option to switch it on anymore, its like "greyed" out if that makes sense
That could be caused by either a software/firmware or a hardware issue.
Try turning the phone off the power it back on and see if it works.
If it is a software (firmware) issue you might be able to fix it by restoring the firmware via DFU mode.
Make sure to backup your phone...just in case.
If it is a hardware issue then DFU mode won't fix a thing or even worse the phone could stop working...so continue at your own risk.
See this video for steps to perform a firmware DFU (Device Firmware Update)
