Question IRQL_NOT_LESS_OR_EQUAL
Nov 10, 2022
4
Been getting this BSOD error recently. Tried resetting windows and disabling WiFi in the BIOS, based on potential other google searches but still getting the BSOD.
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: ffffffffffffffd0, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff8030eccd396, address which referenced memory
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1905
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 4006
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 124
Key : Analysis.Init.Elapsed.mSec
Value: 6031
Key : Analysis.Memory.CommitPeak.Mb
Value: 88
Key : Bugcheck.Code.DumpHeader
Value: 0xa
Key : Bugcheck.Code.Register
Value: 0xa
Key : Dump.Attributes.AsUlong
Value: 1008
Key : Dump.Attributes.DiagDataWrittenToHeader
Value: 1
Key : Dump.Attributes.ErrorCode
Value: 0
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Dump.Attributes.LastLine
Value: Dump completed successfully.
Key : Dump.Attributes.ProgressPercentage
Value: 0
FILE_IN_CAB: 111022-15250-01.dmp
DUMP_FILE_ATTRIBUTES: 0x1008
Kernel Generated Triage Dump
BUGCHECK_CODE: a
BUGCHECK_P1: ffffffffffffffd0
BUGCHECK_P2: 2
BUGCHECK_P3: 1
BUGCHECK_P4: fffff8030eccd396
WRITE_ADDRESS: fffff8030f71c468: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
ffffffffffffffd0
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
TRAP_FRAME: fffffc0f3c2d1600 -- (.trap 0xfffffc0f3c2d1600)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000000
rdx=0000000000000002 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8030eccd396 rsp=fffffc0f3c2d1790 rbp=fffffc0f3c2d1949
r8=00000000b4a0577f r9=0000000001d8f579 r10=fffff8030eccd370
r11=ffffc0f84b000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
nt!ObfDereferenceObject+0x26:
fffff8030eccd396 f0480fc15ed0 lock xadd qword ptr [rsi-30h],rbx ds:ffffffffffffffd0=????????????????
Resetting default scope
STACK_TEXT:
fffffc0f3c2d14b8 fffff8030ee3afa9 : 000000000000000a ffffffffffffffd0 0000000000000002 0000000000000001 : nt!KeBugCheckEx
fffffc0f3c2d14c0 fffff8030ee36ee8 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : nt!KiBugCheckDispatch+0x69
fffffc0f3c2d1600 fffff8030eccd396 : ffffa582bb4401f0 ffffd10062ea5360 0000000000000206 fffff8030ecb5f7e : nt!KiPageFault+0x468
fffffc0f3c2d1790 fffff803229c56f1 : ffffa582c080ae80 0000000000000000 0000000000000000 0000000000000000 : nt!ObfDereferenceObject+0x26
fffffc0f3c2d17d0 fffff803229c5668 : 0000000000000000 ffffa582c0bdda70 0000000000000000 ffffa582bb4401f0 : afd!AfdDerefPollInfoFileObjects+0x45
fffffc0f3c2d1800 fffff803229c4bae : 0000000000000002 ffffd10062ea2180 ffffa582c080aea0 fffffc0f3c2d1949 : afd!AfdCompletePollIrp+0x74
fffffc0f3c2d1850 fffff8030ecb783b : ffffa58200000002 ffffa58200000001 fffffc0f00000000 ffffd10000000002 : afd!AfdTimeoutPoll+0x2e
fffffc0f3c2d1880 fffff8030ecb8fb6 : 0000000000000000 0000000000000000 0000000000000000 0000000000031c14 : nt!KiProcessExpiredTimerList+0x1eb
fffffc0f3c2d19b0 fffff8030ee2bf7e : 0000000000000000 ffffd10062ea2180 ffffa582a7976040 ffffa582bd650080 : nt!KiRetireDpcList+0xed6
fffffc0f3c2d1c40 0000000000000000 : fffffc0f3c2d2000 fffffc0f3c2cc000 0000000000000000 0000000000000000 : nt!KiIdleLoop+0x9e
SYMBOL_NAME: afd!AfdDerefPollInfoFileObjects+45
MODULE_NAME: afd
IMAGE_NAME: afd.sys
IMAGE_VERSION: 10.0.22621.751
STACK_COMMAND: .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET: 45
FAILURE_BUCKET_ID: AV_afd!AfdDerefPollInfoFileObjects
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {9a846440-a090-65b4-c1d4-bc8c6183377b}
Followup: MachineOwner
pls post your full system specs and upload dump file (onedrive maybe) and share link to it
dmp file
Specs:
CPU: Ryzen 3600x
Mobo: MSI B550 Gaming Edge WiFi (WiFi disabled in bios)
Ram: 32GB DDR4 3200 (2x8 Gskill Ripjaws, 2x8 Gskill TridentZ)
Storage: 2TB m.2 NVME
GPU: Msi Ventus RTX 2070
PSU: 650W
download autoruns from here: Autoruns for Windows - Sysinternals | Microsoft Learn
run it as an administrator, find the entries for each of these overclock drivers copies and delete each entry and reboot.
NTIOLib_X64 NTIOLib_X64.sys Sun Jul 9 19:11:47 2017 (5962E263)
NTIOLib_X64_fffff8030d750000 NTIOLib_X64.sys Wed Apr 27 00:47:43 2022 (6268F51F)
NTIOLib_X64_fffff8030d760000 NTIOLib_X64.sys Sun Jul 9 18:54:30 2017 (5962DE56)
NTIOLib_X64_fffff803791d0000 NTIOLib_X64.sys Sun Jul 9 19:13:57 2017 (5962E2E5)
4 copies of overclock driver ntiolib_x64.sys running from different directories are the likely cause of this bugcheck. (remove all copies and reboot)
(if you really need the driver, keep only the mots current version)
Deleted and uninstalled MSI Center (where they seemed to come from), will report back if issues continue.
