Fusion1005 Commendable Jan 15, 2020 153 7 1,585 May 26, 2022 #1 My motherboard, MSI PRO Z690-A DDR4, has 2 8-pins for the CPU, but I'm also buying a set of PSU extensions that only comes with 1 8-pin cable. Is 1 8-pin enough for the 12600k?
rgd1101 Don't Moderator Nov 7, 2011 74,865 4,245 176,290 May 26, 2022 #2 are you plan on using the pc? Reactions: KyaraM Upvote 0 Downvote
Fusion1005 Commendable Jan 15, 2020 153 7 1,585 May 26, 2022 #3 rgd1101 said: are you plan on using the pc? Click to expand... yes Upvote 0 Downvote
Eximo Titan Ambassador May 27, 2010 28,413 5,785 144,340 May 26, 2022 #4 Just buy another cable? Or switch to a modular power supply and get a proper kit? Reactions: KyaraM and rgd1101 Upvote 0 Downvote
