Is 100% GPU fan speed safe?
jacob_174
38
I like to keep my gpu temperature as low as possible, so is keeping it at 100% under full load and 50% at idle safe? Will it damage the gpu or will it lessen the life span of the fans and if so for how long?
yes it is safe, to say it will annoy you to death with the noise it generates
the speed can be set to 0, if your gpu doesn't reach on idle or low load a 30 or 40°c
the gpu under load can reach 80¬ on heavy load, on there usually fans at 70% or higher are enough
remember that the fan speed is there to control heat but mostly noise
