HungryHamster Oct 20, 2022 34 3 35 Nov 3, 2022 #1 I have an ASUS ROG Thor P2 1000w platinum power supply. Will it be enough with this build: https://pcpartpicker.com/list/6VvDTn I will not be doing any overclocking except with XMP on the RAM. I'll be using the 16-pin to 4 x 8-pin PCIe cable from CableMod.
Lutfij Titan Moderator Oct 7, 2009 61,587 6,912 178,440 Nov 4, 2022 #2 Hardware Busters on YT showed a chart that shows that if you want to get 600W to your GPU, you will need a PSU that is above 1.1KW, effectively meaning a 1.2KW or higher PSU. If you get a 1KW unit, you're relegated to delivering 450W to the GPU. View: https://youtu.be/nZcyhcPVxUM?t=196 You've spent about 2000USD on your GPU, a few more cents spent towards a higher wattage PSU is quite frankly a worthwhile investment. Upvote 1 Downvote
