Hi, I am a noob.
That said, my power supply died a few weeks ago and with my current build (and what was available in-store), Thermaltake tr2 430w was fine and that's what I ended up with...
Now here I am considering a quadro 6000 which uses 200w on its own.
Is Thermaltake tr2 430w too low?
Specs are:
1x 60mm (Guessing) fan for
1x intel pentium G3240
1x fan 120mm (I guess)
1x h97m-e/csm motherboard
2x ddr3 4GB Memory
1x dvd rw drive
1x hardrive
1x external HD
1x Gigabit GeForce GT 730
and I use Unity to create games too if that makes any difference. It seems to draw lots of power according to the task manager.
Thank you for your time!
Any more information needed id be happy to offer it.
Ps. I have this other question if anyone has the answer
Specs are:
2x ddr3 4GB Memory
1x dvd rw drive
1x hardrive
1x external HD
[SOLVED] - Does an Asus H97M-E/CSM work with an Nvidia Quadro 6000
Hello. I am considering purchasing an Nvidia Quadro 6000 and I am wondering if its compatible with my motherboard, which is an Asus H97M-E/CSM If you need more information, I'll be more than happy to provide it. Thank you for your time. A noob.
forums.tomshardware.com
