T The_PC_Noob Reputable Nov 28, 2015 1 0 4,510 Nov 28, 2015 #1 I ordered a GTX 960 that requires 8 pin power cable and in my computer I only have 2x 6 pin. Is it okay to use a 2x 6 pin to 1x 8 pin adapter or will it mess up or make my graphics card unstable?
Solution clutchc Nov 28, 2015 That will be fine. You could probably even get by with a single 6-pin to 8-pin adapter. But if you've found a 2 x 6-pin to 8-pin, use it.
clutchc Titan Ambassador Apr 22, 2009 43,160 409 131,790 Nov 28, 2015 Solution #2 That will be fine. You could probably even get by with a single 6-pin to 8-pin adapter. But if you've found a 2 x 6-pin to 8-pin, use it. Upvote 0 Downvote Solution
