[SOLVED] Is a 500W power supply enough for a gtx 1660 super?
crapyahmad
97
I have a gtx 1050ti with a core I7 3770 and an ASRock p65 icafe motherboard
My power supply is A HuntKey greenpower 500W psu.
I want to replace my gpu with a gtx 1660 super but can my power supply handle it? and whats the best gpu that my psu can handle?
Sadly, I have heard of this power supply. The best use of this power supply is something for the recycling center to do. It's so low quality that I wouldn't be running your PC now with it, let alone after spending a few hundred bucks more.
I think it should be fine but I'd be more concerned about that psu you have.... it doesn't look good
Reactions: crapyahmad
I've personally had a motherboard have ports die after using those kind of power supplies.
I've also seen where an adapter that was a molex to sata power adapter caught fire and melted there sata power adapter on a hard drive (not in my system).
Moral of the story. Don't mess with those type of power supplies.
