Solution J J jay32267 Dec 27, 2018 Here's a link. https://www.userbenchmark.com/System/Medion-MS-7748/6129#Compatibility Being it's compatible with a 750 Ti it should be compatible with a 1050....meaning it should have a PCIe x 16 slot.
J jay32267 Champion Mar 16, 2017 10,702 1,324 56,940 Dec 27, 2018 Solution #2 Here's a link. https://www.userbenchmark.com/System/Medion-MS-7748/6129#Compatibility Being it's compatible with a 750 Ti it should be compatible with a 1050....meaning it should have a PCIe x 16 slot. Upvote 0 Downvote Solution
M mateuszsudden Prominent Dec 10, 2018 30 2 545 Dec 27, 2018 #3 Yeah but when I install the card my pc doesn't boot up. It beeps every like 20 to 30 seconds Reactions: ahabmyth Upvote 0 Downvote
J jay32267 Champion Mar 16, 2017 10,702 1,324 56,940 Dec 27, 2018 #4 It could be that the PSU isn't strong enough. or it could be a problem with the card itself (maybe try the card in another machine). Upvote 0 Downvote
M mateuszsudden Prominent Dec 10, 2018 30 2 545 Dec 27, 2018 #5 Ok. But just to be sure I'm upgrading it from a GTX 460. And I heard that the GTX 1050 is consuming less power Upvote 0 Downvote
J jay32267 Champion Mar 16, 2017 10,702 1,324 56,940 Dec 27, 2018 #6 The GTX 1050 consumes 75 watts max. The 460 can draw 160 watts max.....so I don't think the PSU is your problem. Reactions: ahabmyth Upvote 0 Downvote
