Ok, I might. I heard that updating the bios to be able to use 3rd gen cpus will make them function less good so I dont know
Ok, I might. I heard that updating the bios to be able to use 3rd gen cpus will make them function less good so I dont knowit does not mention 3rd gen on the main page (may be old), but, someone does ask about it in support/FAQ, and their answer was yes, it is supported, update BIOS first
Will this make the cpu function worse? Also, which BIOS update do I download?yes with the proper BIOS version installed beforehand.
https://www.msi.com/Motherboard/support/A320M-PRO-M2-V2#support-cpu
Ok. Do you know how much the motherboard would hinder the cpu?function worse? kinda, the old chipset will only let the CPU run as fast as the motherboard can, the newer x570 boards can let the ryzen3 preform unhindered.
the a320m board has many feature unsupported that the CPU supports, some are not useful yet. overclocking and memory speeds are one way that the CPU will be hindered with that board.
you could change CPU's while saving for the new board. then when PCIe 4.0 comes along you can swap boards, upgrade GPU and go at full PCIe 4 speeds.
7b84v34.zip is the BIOS that enables ryzen 3 support.
refer to your motherboard manual for proper upgrade instructions, it can be downloaded from MSI if you do not have it handy
Ok. Do you think that using the BIOS update and then using a 3rd Gen CPU would effect actual use very much? If it isn't a big deal I might just do that.like underclocking the RAM, that is what essentially is happening.
think of it like this its a speed limit, you could go past it but you need a track and your stuck on public roads. bad car analogy aside its is still a huge upgrade over a first gen ryzen. incremental upgrade steps like this are why I chose AMD.
eyes open-A320 is the most basic limited chipset available for the ryzen CPUs, nothing wrong with them is you understand their limits.
You will likely need a BIOS updateI have a gigabyte GA-A320M-S2H that says AMD 3000 desktop ready, will the Ryzen 5 3600 work out of the box with my board?
