Is a Seasonic S12II-520W enough to power these components?
ionutleonardo
20
CPU: Intel Core i5-3350p 3,1 GHz
RAM:6GB DDR3
GPU:GIGABYTE GeForce GTX 970 G1 GAMING 4GB DDR5 256-bit
HDD: 1TB 7200 RPM
Motherboard: ASRock H61M-VG4
Fans on case: 3x120mm , 1x120mm Blue LED.
Keyboard:Razer Blackwidow Chroma (USB)
Mouse:Razer Deathadder Chroma (USB)
Headset:Razer Kraken 7.1 Chroma (USB)
6+2 pin PCIe
6 pin PCIe
It has the needed GPU connections and power to run the setup.
A GeForce GIGABYTE GeForce GTX 970 G1 GAMING 4GB needs 28 amps on the 12v+ rail and at least a 500 watt PSU with 1 - 6 pin and 1 6+2 pin PCIE power connections.
The SEASONIC meets these requirements.
