NONE of the above, IMO. Those products are all too thick. IF you wanted to try, you would want a very thin oil, like sewing machine oil.So, one of my fans is not working due to the lube possibky drying out in it, and so im looking into using anything to fix it up, so would brake fluid be good? If not, ive also got transmission and engine fluids.
NO. You replace the fan with the worn bushings. You do not apply oil, WD40, brake fluid etc. as that will only make things worse.So, one of my fans is not working due to the lube possibky drying out in it, and so im looking into using anything to fix it up, so would brake fluid be good? If not, ive also got transmission and engine fluids.
If we went by https://www.overclockers.com/em-spinning-lubricate-pc-fans/, then engine oil apparently does work. Though they suggest using sewing machine oil.
You only need a dollop of it either way.
