Is Corsair VS450 450 Watt PSU good for my system?
Minibicki
22
I am building my own PC and I don't know what sort of power supply I should get. Here are my specs:
MSI Z87-G45 Motherboard
Nvidia GeForce GTX 750 Ti GPU 2GB
16GB RAM (Ballistix)
Intel Core i7 4770K 3.50GHz
Seagate 1TB Barracuda Internal Hard Drive
Edimax Wireless-N150 PCI Adapter
Wired Mouse and Keyboard
Zalman Z11 Plus High Performance Mid Tower Gaming Case with GREEN LED
Thanks! :)
The XFX P1-550S-XXB9 is not Intel Haswell Compatible. XFX even says it's not compatible. JonnyGURU.com has also shown that it may/will run into problems with Intel's C6/C7 power states when you see the Crossload tests.
The following are confirmed to be Haswell Compatible and are within your $80 budget limit:
Seasonic S12G-450
http://pcpartpicker.com/part/seasonic-power-supply-s12g450
XFX TS Series 550W (P1-550G-TS3X)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
SeaSonic SSR-450RM
http://pcpartpicker.com/part/seasonic-power-supply-ssr450rm
XFX P1-650S-NLB9
http://pcpartpicker.com/part/xfx-power-supply-p1650snlb9
Seasonic S12G-450
SeaSonic SSR-450RM
XFX P1-650S-NLB9
Thanks man! Gr8 help! :)
