Is everything good with my parts?
Sauhta
100
Motherboard: Gigabyte - Z370 HD3P (rev. 1.0)
Cpu: i7 8700k
Gpu: Gtx 1060 3gb
PSU: Extreme Power Plus 460W
Cooler: H60 AIO Liquid CPU Cooler
Ram:Corsair Value Select 8GB DDR4 2133MHz
rethink the power supply. 312 Actual Watts, its been discontinued, you will never be able to overclock with that unit. --- necessity
if you can get faster DDR4 (2400-2666Mhz) and try to get a set, 2x4GB over a single 8Gb stick. --- optional
rest looks good
rest looks good
Unless they have updated the design that psu I can find reviews over 10 years old and it was mediocre then. If the design is unchanged I doubt it supports modern cpu power states. You really want a good quality modern 500w unit minimum.
Is this pc just for gaming? If yes drop the cpu to a 8600k and get 16Gb RAM and upgrade to at least the 1060 6Gb.
Also that AIO cooler is beaten by cheaper air coolers. With get a similar priced air cooler or go for a better AIO.
