Richipete Feb 1, 2020 18 0 10 Dec 18, 2020 #1 I have 2 sticks of 8GB Corsair Vengeance 3000 MHz, but my mom got me 2 more but the speed is 3200 MHZ. Is this okay or what?
Solution USAFRet Dec 18, 2020 Richipete said: Oh ok so its perfectly fine then? Click to expand... Not necessarily. Mixing RAM always carries a risk of not working at all. Since you have it, try it. But don't be shocked if it fails. RAM is sold as a set, to ensure it all working together.
D Deleted member 2720853 Guest Dec 18, 2020 #2 It will just run at the speed of the slowest RAM stick. In this case, 3000 MHz. Upvote 0 Downvote
Richipete Feb 1, 2020 18 0 10 Dec 18, 2020 #3 TheNerdyGlaceon said: It will just run at the speed of the slowest RAM stick. In this case, 3000 MHz. Click to expand... Oh ok so its perfectly fine then? Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,849 22,157 184,590 Dec 18, 2020 Solution #4 Richipete said: Oh ok so its perfectly fine then? Click to expand... Not necessarily. Mixing RAM always carries a risk of not working at all. Since you have it, try it. But don't be shocked if it fails. RAM is sold as a set, to ensure it all working together. Upvote 0 Downvote Solution
