Yes, and do you know what it means, "64 bit instructions"? :roll:
What about 64bit GPRS
Well, indirectly yes
since GPRs can (usually) hold addresses and as such, that would imply 64 bit addressing.
Perhaps i'd say, 64 bit PC (Program Counter)... but yes this is an old debate and i don't think a real proper definition for it exists.
There were times where it referred to the width of the execution path, the data bus, the addresses, the registers...
With x86 everything is more complicated, as you have 32bit addressing, but 64bit and even 128bit execution paths and registers, then physical address extensions to 36bit even before 64bit instruction were introduced, etc.
Anyway, i'd say that today the most commonly accepted definition for a 64 bit CPU, is that the
instruction set is capable of 64 bit addressing (regardless of the number of address lines physically available to a certain CPU).
I really like your insight with the post count of 100. Your posts are more worth than thousands from hundrets other members on THG
To bad, there are only few people like you here.
