Question Is it a GPU or Motherboard problem?
Carlsos
12
Hello, I have a question, a few months ago I installed a new GPU (gtx760) it worked fine except for some occasional glitches, yesterday this got a lot worse and I no longer have a graphical interface, only terminal (gentoo linux), so I thought it would work (gtx760) ) was the problem because it was used and I installed my old graphic (gt610) that worked fine, but now it doesn't work either, I get only terminal with strange characters
Now I'm writing this with the integrated graphics (NVIDIA GeForce 7025 / nForce 630a), which works but it's slower than a snail and I think it has a problem showing the bios because the initial logo only shows 640x480 and not 1920x1080
Glitch GTX 760 in the second ~45
View: https://www.youtube.com/watch?v=CPgdWdHkUNY
Serious glitch GTX 760
View: https://www.youtube.com/watch?v=CdL5oyDj69c
Gt610 good, I don't know why it doesn't work now
View: https://www.youtube.com/watch?v=TVAwP9UAQJQ
So now I don't know if the artifacts that I saw with the gtx760 were a problem with the graphics card or with the motherboard, because now when I put the card that I thought was good it also fails.
And I also did a vram test with mats, everything went well, I tried the 2Gb
My motherboard is MSI gf615m-p33
Corsair CV550 Power Supply
This appears in dmesg when the squares were output
Code:
[  211.751968] NVRM: GPU at PCI:0000:02:00: GPU-7c263333-8cd6-51f8-2903-9cb409f9738b
[  211.751977] NVRM: Xid (PCI:0000:02:00): 31, Ch 0000005a, engmask 00000101, intr 10000000
[  245.522731] NVRM: Xid (PCI:0000:02:00): 69, Illegal Class Error: ChID 0012, Class 00000000, Offset 00000230, Data 000000cf
[  245.923379] NVRM: Xid (PCI:0000:02:00): 31, Ch 0000005a, engmask 00000111, intr 10000000
[  295.616799] NVRM: Xid (PCI:0000:02:00): 13, Graphics Exception: Shader Program Header 1 Error
[  295.616804] NVRM: Xid (PCI:0000:02:00): 13, Graphics Exception: Shader Program Header 2 Error
[  295.616806] NVRM: Xid (PCI:0000:02:00): 13, Graphics Exception: Shader Program Header 3 Error
[  295.616808] NVRM: Xid (PCI:0000:02:00): 13, Graphics Exception: Shader Program Header 4 Error
[  295.616809] NVRM: Xid (PCI:0000:02:00): 13, Graphics Exception: Shader Program Header 9 Error
[  295.616811] NVRM: Xid (PCI:0000:02:00): 13, Graphics Exception: Shader Program Header 18 Error
[  295.616813] NVRM: Xid (PCI:0000:02:00): 13, Graphics Exception: ESR 0x405840=0x8204021e
[  295.616828] NVRM: Xid (PCI:0000:02:00): 13, Graphics Exception: ChID 0012, Class 0000a097, Offset 00001614, Data 00000000
[  295.686127] NVRM: Xid (PCI:0000:02:00): 31, Ch 00000028, engmask 00000111, intr 10000000
It definitely looks like a GPU issue/problem, IMO. Not the mobo. Most likely the GPU VRAM is corrupted.
That's an XID message, which means a GPU error, most likely due to the GPU being programmed incorrectly, or the commands sent to the GPU are bad/corrupted for most part. The Nvidia driver prints this message to the operating system's kernel log/event.
But this could either be a hardware, software, and/or a user application error. Are you using the "stable" version of Gentoo Linux ?
I don't think it's a stable version, I use a lot of masked packages, but I don't think it's a gentoo problem, I've seen these problems on windows too.
Why does this affect the good GPU? The gt610 has no problems and still looks like video 3.
I did VRAM tests for hours and they all come out correct so I don't know what it could be
I know I have RAM problems, I disabled a few MB of RAM and the system recovered stability, maybe I missed a bad sector, I didn't think that could affect the video, I'm going to removing it.
