Is it okay to take out fan bracket from arctic cooler 7 pro rev 2?
Jun 19, 2018
I need to do this in order to fit the ram sticks. Anyone know if this will change the performance?
Cpu: Intel Core i5 8400
You can temporarily remove the fan to install the RAM sticks if that is what you meant. Obviously, you can't run w/o the fan or the temps will skyrocket.
It's hard to believe that that compact little cooler is in the way of the RAM sticks tho.
clutchc
Ambassador
