Is it okay to use a 500w PSU for a 250w system?
HELLOYURI
5
Hello.
I'm building a computer for the first time and I've been looking for a decent PSU. I won't add a graphics card at the moment but I have plans to get one after 6~12 months. Until that, is a 500w PSU too much? I got an i7 4790k but I won't overclock for now, maybe in the future. By the way, is Haswell compatibility really necessary?
Found these 3 options around 500w:
CoolerMaster Elite V2 500W RS500-PCARN1
XFX Pro 450W Core Edition P1-450S-X2B9
Seasonic ATX 520W S12II-520
Thanks, and sorry for bad english.
Plan ahead. Get an idea of what GPU you want later and get the PSU for it now. A good PSU does not come cheap. With a "k" CPU you may want to overclock later on (assuming you have a proper board). Haswell compatibility is to lower the amps the CPU draws when inactive and still remain stable. If the PSU is not Haswell compatible, you can disable c6/c7 states in bios. The PSU's you listed are ok for now if you must get one.
Brillis Wuce
You can't have "too much wattage". You could throw in a 1600 watt PSU into your system and it would work. Is it necessary? Definitely not.
500 watts is enough for the majority of systems with a single video card, but there are some that require more, and any SLI/Crossfire option uses more.
Any idea which video card you'll get?
Out of those 3 that you listed, go for the Seasonic.
HELLOYURI
5
A single GTX 760 would be fine. I will buy it later along with a watercooler (H60 or H80). I'm looking for a PSU that will not exceed the system needs, but will allow further upgrades like these.
Dark Lord of Tech
Retired Moderator
