D Dr3v1R Reputable Apr 19, 2016 14 0 4,510 May 9, 2016 #1 I have AMD R9 270x and amd x4 860k on msi a68hm-e33 motherboard is it possible that MB is bottlenecking my system cuz i cant get stable 128+ fps in cs go or is it that my cpu is baD?
Solution TerryLaze May 9, 2016 This game only uses one core for running game code,so whenever it needs CPU power you will get lower FPS.
TerryLaze Titan May 9, 2016 10,933 3,111 76,440 May 9, 2016 Solution #2 This game only uses one core for running game code,so whenever it needs CPU power you will get lower FPS. Upvote 0 Downvote Solution
D Dr3v1R Reputable Apr 19, 2016 14 0 4,510 May 9, 2016 #3 TerryLaze : This game only uses one core for running game code,so whenever it needs CPU power you will get lower FPS. So i need a better CPU or is there a any other way Upvote 0 Downvote
TerryLaze Titan May 9, 2016 10,933 3,111 76,440 May 10, 2016 #4 If you can't live with ~100fps then yes,either overclock or get a CPU with better IPC/single core performance. Upvote 0 Downvote
