Question Is it possible for my asus prime b550m-k motherboard to use 6 fans?
Feb 4, 2024
My asus prime b550m k motherboard only has 3 fan slots. I'm wondering if the motherboard is compatible with a PWM 4 port fan hub so I can plug 6 fans in instead of just 3. Is this possible? Is the power outage great enough for 4 fans out of 1 slot?
What are the makes and model of the fans you want to work with? If they're all WM, just pick up a PWM fan hub similar to this;
and you can use one header on the motherboard to manage all your fans in your build/case.
CORSAIR iCUE AR120 RGB Digital 120mm ARGB-Compatible Fans - Triple Fan Kit - Black https://amzn.eu/d/cXlkk0j
These are the fans I've bought
I'm not sure what amount of pins, this is my first pc and I'm struggling to get all compatible things
those fans are rgb fans they need a rgb header your motherboard doesnt support rgb.
the fans will power up of the fan headers but wont light up as they isnt a rgb header to connect to on the motherboard.
what is your full system specs ?
fans that would work with that system these dont require motherboard rgb connection can use a remote
https://www.amazon.co.uk/Aerocool-D...9&sprefix=led+fans+120mm,aps,142&sr=8-19&th=1
View: https://www.youtube.com/watch?v=OYwm28-n5sQ
