Is it possible to connect a Multi-Function Router to a PC via LAN and for it to get the Internet via WiFi?
Ariel Or
4
Hi everyone!
I have a 3 in 1 Multi-Function Router (EDIMAX N300 BR-6428nC) and I need it to do something very specific that I've been told by the seller that it can be done with this device.
Basically what I need from this device is to connect to a PC via the LAN port and for the device to get the Internet via WiFi from the main router in the house like so:
|Main Router| ____(WiFi)____ |BR-6428nC| ---(LAN Cable) --- |PC|
(Hope it made any sense 😀)
What I've tried so far is to set the device as a WiFi Extender and it did get the Internet from the main router (Checked it on a working WiFi PC) but the PC connected via LAN cable is not recognizing the device at all.
Is what I'm trying to achive even possible with this device? If so, I would love someone to show me how. And if it's not possible, Can it be done any other way?
Thank you and have a good day and Happy New Year!
Ariel.
Thanks I'll check it out!
I've tried both the LAN and WAN (although AFAIK this one shouldn't work)
What you want is a client bridge. The mode is not mentioned in the manual. The extender mode might or might not be made to work as a bridge.
