Is it possible to fix a bent Power supply pin?
Charlie Pawlak
192
I got a Corsair CX600 600w power supply, but when I did the green+black wire test, I accidentally split the green wire pin on the ATX 24-pin. Will the power supply still work like this? Is there any way to fix?
Get yourself a pair of needle nosed pliers or something thin enough to get in on each side and give it a bit of a squeeze, all the connectors are split on top, that one just separated at bit. If you push it together so the top two bits touch it should work just fine. I think in its present state it would bind going into the main ATX connector on the board.
Thanks man!
