NOT_PROVIDED_790 :
97 chevy automatic 4.3l vortec.
Yes, although it generally works a little better if you connect the cable from the assisting battery's negative terminal to the "appropriate" jumping location, usually a lug near the midline of the engine. The reason is that provides a better ground than trying to connect to the dead battery's negative terminal. Modern U.S. cars are negative ground and there is no more direct of a method of grounding than directly clamping to some large paintless metal part close to the starter. Also, most batteries have way more than enough capacity to start their vehicle unless they are very old, so a relatively small car battery can start a truck easily as long as it is fairly new. I used to live in the...
