[SOLVED] Is it possible to use a larger-sized display with similar resolution & connector pins, on a small-sized display notebook?
Dec 20, 2018
26
I have a 14." notebook, which has a cracked screen. The notebook has a magnesium alloy body, and works fine. As it is a >10 year old notebook, it's rather difficult to find a replacement screen, and even if I could find one, it's probably uneconomical to buy and replace.
By chance, I came upon a larger (15.4") display, with similar resolution and connector pins, as the 14." display.
My question is: aside from the different size hinges and lid, since the connector pins are similar in number, and screen resolution is similar, if I transplant the larger into the smaller, can it work?
At the moment, I am not too concerned about aesthetics, nor the different hinge size, yet. I just need to know if it is likely to work or not? Thanks
D
Quite unlikely to work as "pins are similar in number" does not equal same signals on the same pins, especially on a 10+ year old unit.
