Hi team!
First off, this is my very first time posting on here and I'm very excited.
So Im currently building my setup but I have a little problem with USB components, I have these:
Yup that's quite a few, luckily, I have an NZXT internal USB hub that takes care of the first 5 on that list as it has 3 internal and 2 normal USB ports, but that leaves me the LCD display and I'm so tempted to just split one of the NZXT's internal USBs into two using a cheap internal USB 2-way splitter board but I'm worried about voltage delivery as I haven't seen anyone done this before.
So, my question today is this, is it safe to use an internal USB splitter on an NZXT internal USB hub? If not, apart from routing it at the back, what other options do I have?
Thank you so much!!
- NZXT Grid v2 (internal USB header)
- NZXT Hue 2+ (internal USB header)
- Asus ROG ryuo AIO (internal USB header)
- An Arduino nano board with an OLED based on ESP8266 (normal USB header)
- Razer Chroma RGB hub (internal USB port or any standard micro USB cable)
- 5" TFT LCD Display (standard micro USB to normal USB)
Thank you so much!!
