Is it wrong to have 2 sound drivers installed?
Jorgeavx
22
I have sound coming from 2 different speakers http://i.imgur.com/7AKTa8W.png
If i keep the razer drivers installed and i uninstall the other drivers will i lose all my sound?
Do i have to leave them both installed?
edit: i want to use my razer drivers because they give me better sound quality and would like to remove my other sound drivers. Is that safe?
Are you using 2 sound devices or just one? If it is just one set of speakers connected to the rear port, it can only use one driver at a time. Whether you disable/uninstall the other driver doesn't matter.
yeah it uses both but i only want to use one. it gets really annoying. that's why i was wondering if it would be bad to uninstall the other one
No, you can uninstall it. No problem.
