Sorry I think we got your core and socket temps confused.
If the 55C core temp reading is based on properly calibrated software then that's still 15C away from the maximum thermal margin for the CPU and perfectly fine.... Again, you really should use AMD Overdrive software for the actual CPU core temps. Within the scope of practical overclocking efforts, (typically <1.55V), the CPU can be operated continuously at any temp within the allowed thermal margin with no consequence to durability.
The 68C socket temp reading is pretty normal for that sort of load. If I recall the board will begin throttling the CPU at 70C or 80C socket temps (can't recall). It's common to have socket temps be the limiting factor for an overclock, especially when using AIOCLCs, which actually tend to make air-flow over the VRMs worse. If you can install a small fan over the VRM heatsink these temps will drop and open up some more headroom.
Obviously you would probably need a bit more than 1.41V to be stable at 4.8ghz, but I suspect finding a usable 4.8ghz overclock is probably well within the practical limits of the hardware you have there.
The durability of the system will not be compromised by disabling power saving features. You can run with or without them it really doesn't matter.
